failing AGP, FIC PA-2013
First post, by pshipkov
Not far ago relative gave me FIC PA-2013 2.1 SS7, AGP, ATX motherboard.
Tested it briefly - worked as expected. Overclocked well and everything.
Left it collecting dust for several weeks.
Turned it on 2 days ago to check something - very unstable - rarely finishes POST even with the most conservative FSB frequency, BIOS settings, clock multiplers, etc.
Tested it with Quadro2 Pro AGP which worked great the first time around.
At some point switched to MGA PCI - instant stability - everything back to normal.
Considered replacing the electrolytic capacitors - the usual cure.
Waiting for them to arrive since don't have that specific type.
Tonight touched with finger different components on the board and to my surprise a very compact 9435A mosfet on the right side of the AGP slot was burning hot. Left a red mark on me.
There is a diode right on top of it which may be another potential problem.
Is it normal for such a small element to be so glowing hot ?
Checked online - no such info, but data sheet hints at high temperature range - over 100C.
If somebody has such board - any chance for a cross-check ?
retro bits and bytes | DOS media library
Reply 1 of 14, by TheMobRules
Apparently there are versions with this board that have problems with the regulator that delivers power to the AGP slot. You may want to read this thread.
Reply 2 of 14, by pshipkov
Thank you for the link.
I remember seeing that thread before but forgot about it.
So last night I thought that I figured out the source of agp problems.
All was working fine. Snapped some pics and was thinking to post the solution, but tried 2 hours ago and thing were not fixed fixed.
So looking some more ...
Reply 3 of 14, by Repo Man11
Maybe you'd be best off with a PCI card? Phil's video shows that there isn't much of a performance difference between a PCI and AGP FX5500: https://www.youtube.com/watch?v=Ia1zNRZE8Mg
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Reply 4 of 14, by The Serpent Rider
More than 50% performance penalty in games which can utilise transformation engine.
Reply 5 of 14, by pshipkov
Agreed.
In the initial post i stated revision 2.1, but it is actually 2.0
Here is what seems to have fixed, or at least improved, the AGP situation for this motherboard:
The attachment fic_agp.jpg is no longer available
This element gets hot as high as 80C when the AGP slot is occupied.
That temperature is a lot given the small surface area.
Don't know if it was getting that hot a month ago when i acquired and tried the mobo for a first time and everything worked fine.
Strapped a heatsink - Quadro2 Pro suddenly light up again.
Notice the fan on the right side - added it but don't know if it makes a difference.
Need to check the result more thoroughly.
Reply 6 of 14, by igna78
The Serpent Rider wrote on 2021-10-30, 05:14:
Maybe I misunderstood the post, but I dare to say that probably a TnL video card on an SS7 system (even with a K6-III + @ 600MHz) would not be exploited adequately and I believe that games that need TnL would find their limit in the CPU even before the PCI bus at 33MHz.
Of course I agree that compared to AGP's 66MHz, without considering the rest, the 33MHz PCI bus already reduces performance, however for a system that covers DOS game and was Win98 before I think that, without getting a headache from the FIC motherboard (certainly not among the most reliable except in later reviews), a good PCI video card can do well 😉
Reply 7 of 14, by The Serpent Rider
That includes a lot of OpenGL games though. Quake 2 can use TnL engine.
Most likely not normal and it needs to be replaced.
Reply 8 of 14, by matze79
I guess Quadro 2 draws too much power from the regulator ?
Reply 9 of 14, by pshipkov
Replacement is on the way. Will see what happens.
I thought it is the Q2Pro, so tried other AGP cards - TNT2, GF256, Permedia, S3SomethingSomething - all caused the same instability.
It is a motherboard thing for sure.
Reply 10 of 14, by rasz_pl
I seem to remember fixing AGP instability back in the day by connecting AGP 3.3V supply directly to ATX socket with a thick wire underneath the board.
seems this board was factory fixed in same way in later revisions Re: FIC PA-2013 Ver 2.1 and Voodoo3 3000 AGP
Reply 11 of 14, by The Serpent Rider
2.0 and 2.1 are identical and use the same PCB - 2.0 E-O036. 2.1 is minor revision which confirms to PC99 standard (see link), while 2.0 doesn't, because ATX I/O and ATA connectors are not color coded.
Reply 14 of 14, by pshipkov
I didn't see vrm with or without heatsink near agp slot on the 2.0 pcb here.
Can you point it on a picture ?
