s3 trio3d fell silent
First post, by pshipkov
Stopped working recently.
Replaced capacitors with fresh ones - still silence.
Tried it in 2-3 different motherboards - silence.
Any ideas ?
Providing front/back photos in case somebody spots something i missed.
The attachment 1.jpg is no longer available
The attachment 2.jpg is no longer available
retro bits and bytes | DOS media library
Reply 1 of 10, by The Serpent Rider
Time to upgrade it to pin compatible Savage 3D/2X!
Reply 2 of 10, by TheMobRules
There's something on the bottom memory chip, if it's metal it may be bridging two legs:
The attachment EliteMT.jpg is no longer available
Other than that: does the S3 chip feel too hot? And can you try to dump the BIOS using a programmer to verify it's not corrupted?
Reply 3 of 10, by Doornkaat
Bad Video BIOS EEPROM?
Try booting with a PCI graphics card and see wether the AGP S3 is detected by OS.
Reply 4 of 10, by pshipkov
TheMobRules
You gave me a glimpse of hope.
Removed the spec but still no lights.
Doornkaat
Burned new BIOS on trusted EPROM.
Will try your second suggestion.
The Serpent Rider
That or either move on entirely.
Reply 5 of 10, by Tetrium
pshipkov wrote on 2021-11-15, 19:59:
TheMobRules You gave me a glimpse of hope. Removed the spec but still no lights. […]
TheMobRules
Doornkaat
The Serpent Rider
What was the spec between the legs anyway?
You could also try cleaning the contacts with some rubbing alcohol. Worth a shot and I've revived quite a bit of seemingly dead hardware this way.
My retro rigs (old topic)
Report spammers here!
Reply 7 of 10, by Garrett W
Try cleaning the contacts with an eraser.
Reply 8 of 10, by Ydee
Is it just dirt or a scratch?
Reply 9 of 10, by Doornkaat
pshipkov wrote on 2021-11-17, 08:27:
I think it was piece of thermal paste. Hard to say really.
Negative on agp recognition. Card is gone.
Agree, that sounds like a dead chip.
Sorry.😐
Reply 10 of 10, by pshipkov
@Doornkaat
Yeah.
@Ydee
This was me - slipping the soldering iron end while vacuuming the joint point for recaping.
Lighting makes it look much stronger than it is - it is a gentle scratch on the surface of the silk screen.
Good eye tho 😀
