First post, by Predator99
Just like to share some data about the EIZO / NANAO TIGA MD-B09 TMS34010.
Unlike for many other TIGA cards the driver for this card is still available. I expected to be able to connect a VGA screen to the "CN2". However this connector provides only the same signal that is available on the cinch-out - and nothing else.
It seems that the card runs only with some special fixed frequency monitor. It is only black and white with 3 resolutions to select from. No color, no VGA. When connecting to a composite-in only some moving trash is displayed. The card is working, but without a suitable monitor it seems to be pretty useless.
Somebody has an idea what kind of monitor is required?
914.41 KiB
649.65 KiB
662.54 KiB
1.91 MiB
23.33 KiB
Reply 1 of 7, by weedeewee
Determining the HF and VF using an oscilloscope should give an idea of what monitor could be made compatible to that card.
Do not ask Why !
Reply 3 of 7, by weedeewee
Composite video contains both the HF and VF.
A composite signal is easy enough to visualize on a oscilloscope.
Do not ask Why !
Reply 4 of 7, by Predator99
I only own a logic analyzer. What you can see is that the frames switch with 60 Hz.
So the question is more if there is a possibility to display a 1280 x 1024 composite signal on a modern screen?
31.25 KiB
23.5 KiB
Reply 5 of 7, by Predator99
Just found the solution...my DELL supports Composite Sync on green - simply attach the output signal to the green signal on the VGA connector 😁
1.03 MiB
Reply 6 of 7, by weedeewee
ah yes, the age old knowing which piece of hardware you own has that particular ability you once thought you'll never be using 😉
Neat. though shouldn't it be 1600x1200 ?
and ... Which games can you play on that 😁 though i guess it was probably meant for some CAD applications.
Do not ask Why !
Reply 7 of 7, by Predator99
Unfortunately no games.
There is the number9 demo
EIZO MD-B12 TIGA TMS34010
I also was looking forward to test this
TIGA Promotional Kit *Imaged*
But it complains about only 2 colors on this card.
321.17 KiB
