First post, by fargo
I currently don't have a 486 motherboard with PCI slots in my collection and want to get one.
I fond a motherboard using SiS 497 chipset with ISA, VB and PCI. I also found one using UMC UM8881 chipset but with only ISA and PCI.
I was going to get the SiS board based on its features, but read an article (here) saying the SiS chipset is slower and not the best option for 486.
What do you think? Which board should I get?
Thank you
Reply 1 of 14, by The Serpent Rider
Depends. To begin with, the difference between them is small and performance can fluctuate on motherboards with identical chipset. SIS496/497 can work on 66 MHz FSB with 66 Mhz PCI bus on certain boards though.
Reply 2 of 14, by gerwin
fargo wrote on 2021-12-26, 01:40:
Did you read the update there as well? Where it says that a wrongly set turbo jumper/switch was to blame.
Reply 3 of 14, by pshipkov
I have all the respect for Michal Necasek, but this particular article is off.
That SIS board is incomparable to Alaris Cougar.
It is just a next-gen product on a different level.
SIS 496/497 is the better 486 chipset compared to UMC UM8881.
But make sure you pick the right motherboard.
retro bits and bytes | DOS media library
Reply 4 of 14, by fargo
gerwin wrote on 2021-12-26, 02:53:
Yes, but even after fixing that, the performance wasn’t top notch.
Reply 5 of 14, by fargo
pshipkov wrote on 2021-12-26, 05:12:
I found exactly the same motherboard mentioned in the article.
Reply 6 of 14, by Disruptor
Be sure that it has a PS/2 mouse port or connector.
Reply 8 of 14, by Disruptor
fargo wrote on 2021-12-26, 13:54:
Disruptor wrote on 2021-12-26, 13:23:
Is this related to performance or just for use convenience?
That depends on the point of view.
As a former semi professional gamer I would say that optical mice improve gaming skills and performance over wheel-based mice.
Reply 9 of 14, by fargo
Disruptor wrote on 2021-12-26, 14:44:
Ah, I see. Thank you
Reply 10 of 14, by SSTV2
A stock 4SAW2 motherboard will most definitely lose, in terms of performance, to more known motherboard manufacturers which used the same chipset. This motherboard has a few questionable chipset features/BIOS option implementations, but the main drawback for it is a badly implemented L2 cache policy settings in older BIOS revisions, which would result in a much lower RAM/L2 throughput than this chipset is supposed to deliver.
A properly modded 4SAW2 will fly high, here are some results of 4SAW2 with an am5x86 clocked at 175MHz (58.3x3), 8MB FPM RAM and lowest possible RAM/L2 timings this chipset can handle:
The attachment 175MAXT.gif is no longer available
Reply 11 of 14, by fargo
Interesting! I've seen several BIOS versions over the internet for the 4SAW2, and even an Asus bios modded for it. Would a simple BIOS update fix this board's performance?
Reply 12 of 14, by SSTV2
Yes, its main issue is omitted chipset options in BIOS, though, official BIOS could be fixed with a "Modbin" BIOS editor.
Reply 13 of 14, by AlexZ
VLB performance should not be underestimated. After all it was a much simpler bus and it had direct access to 486 memory bus.
Rather than performance which should be similar, I would consider whether you will be taking advantage of:
- PCI IRQ sharing - allows to install more expansion cards
- larger selection of PCI expansion cards which are newer and have more memory. You could use a 3D graphics card in 486.
- the board will likely come with AWARD BIOS which supports larger drives than those old non-LBA AMI BIOSes
- PCI PnP (not a big advantage in my opinion)
I would also vouch for PS/2 mouse connector due to ability to use optical mouse.
If you would benefit from the above advantages then I would pick PCI board even if it had slightly worse performance than VLB board.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 14 of 14, by fargo
AlexZ wrote on 2021-12-26, 21:27:
Both boards have PCI; one has VLB in addition.
I went ahead and ordered the Soyo board with SiS496 chipset. From the feedback I got here, it seems the better option compared to the UMC board.
