First post, by SPiKA85
Hi everyone!
I just got an Intel D815EEA2U Mainboard.
It works great with a Tualeron 1.2GHz, but when I install a Pentium III-S 1.4 Tualatin. It doesnt boot.
It has BIOS P19.
I tried to find version P21 but I cant find it.
Does anyone here have it?
Thank you very much.
Kind regards.
Reply 1 of 10, by kitten.may.cry
SPiKA85 wrote on 2022-05-25, 16:50:
Hi everyone! I just got an Intel D815EEA2U Mainboard. It works great with a Tualeron 1.2GHz, but when I install a Pentium III-S […]
Hi everyone!
It has BIOS P19.
Kind regards.
Quick Google search yielded that you need P21 BIOS.
Stay in touch.
Reply 4 of 10, by PC Hoarder Patrol
Official 512KB cache support for PIII-S was added at P14 and removed again, even for your D815EEA2U(niversal) which has both FC-PGA & FC-PGA2 support, sometime after P17. You'll find it and P18 thru P21 at this link - http://cwcyrix.duckdns.org/intel-legacy-files … 0D815EEA2/BIOS/
Full BIOS Histoty
P21-0039.pdf
94.19 KiB
56 downloads
Reply 6 of 10, by PC Hoarder Patrol
Interesting...I did see a couple of posts which mentioned that that the U models did have support with the latest BIOS, but Intel never seemed to openly publish this, though I've seen NIB D815EEA2U boards which actually shipped with P21 so maybe not that surprising. Glad you got it working anyway 😀
Reply 8 of 10, by SPiKA85
Another weird issue I have is that the D815EEA2U is now working with 2x256MB Kingston PC133 CL3 RAM... but if I try to install a single stick of 512MB Kingston KTM0055 PC133 CL2, it doesnt boot.
The CL2 stick works well in a D815EEA2 (non U) board.
Reply 9 of 10, by aaron158
SPiKA85 wrote on 2022-05-27, 20:28:
i think i had the same issue 256mb sticks work but not 512.
i would suggest getting 2x256mb pc133 cl2 if u want to squeeze every bit out of it. the def between cl2 and 3 though is pretty small but if u can find some 256 cl2s for cheap might as well.
Reply 10 of 10, by karakarga
My single stick 512Mb Kingston KVR13364C2/512 works well on Intel D815EEA and D815EEA2, I have two from those mainboards, only A55991-803 supports Tualatin.
One side of the box, there is L and U indicators. Those represent L = Lan (network) and U = aUdio. Those extensions are not related with actual board names, but batch codes.
https://www.ebay.com/itm/225969430289 here the shown model is LU and has Lan and audio on board.
    353.93 KiB
    264.2 KiB
    305.12 KiB
    171.65 KiB
