First post, by pete8475
I've had a bunch of parts sitting around not being used and have decided to build an "overkill" Pentium 4 machine running Windows XP.
Specs:
Intel Pentium 4 661 (3.60GHZ, LGA775)
Gigabyte GA-P35-DS3R Rev 2.0
4GB DDR2-800 RAM
120GB Kingston SSD
Geforce GTX770 2GB
There is also a 3.80GHZ 775 P4 available from Chinese sellers on ebay but the prices are silly.
For fun I'm going to run benchmarks to compare the performance with the GTX770 to a 750TI and a 710 (all 2GB versions).
Why am I doing this? No idea, I just have a weird nostalgia for the P4 era and was very annoyed with my RD-RAM P4 build not being able to have 2GB of 1066 RD-RAM, so I'm taking things up a level with a 775 CPU and DDR2 memory.
EDIT - benchmark results
GT710 (64bit mem bandwidth version)
3dmark01 - 21795
3dmark03 - 16525
3dmark05 - 8611
Aquamark3- 75532
UT2003 1280x960
Flyby - 83.222321
Botmatch - 70.535759
GTX750TI
3dmark01 - 28234
3dmark03 - 42398
3dmark05 - 9127
Aquamark3- 80069
UT2003 1280x960
Flyby - 254.306580
Botmatch - 80.257607
GTX770
3dmark01 - 28298
3dmark03 - 44264
3dmark05 - 9125
Aquamark3- 80905
UT2003 1280x960
Flyby - 257.273712
Botmatch - 81.193909
    330.61 KiB
    127.47 KiB
Reply 1 of 64, by X86
Yeah 3.8 ghz P4s are pricey because they are the highest clocked ones out of the series... 4.0 ghz was canceled.... spare parts builds are fun... sounds like a good rainy day project to me.
Reply 2 of 64, by TrashPanda
The 661 is a great CPU and that 670 3.8Ghz model is one of the Presshot versions which I cant recommend buying even if it was cheap.
Just bump the 661 to 3.8, you'll still have a better CPU than the Presshot model, I ran mine at 4.0 for ages.
Reply 3 of 64, by rasz_pl
>Pentium 4 661 3.60 GHz
Release Date: Jan 5th, 2006
Release price: $401
Wonder if its slower than Conroe based Celeron 420 1.6 GHz 😀 Those went from 8x200 stock all the way to 8x333 without breaking a sweet and cost something stupid like $35 when I got mine back in the day.
https://en.wikipedia.org/wiki/List_of_Intel_C … _based_Celerons
Release Date: June 2007
Release price: $39
Reply 4 of 64, by pete8475
rasz_pl wrote on 2022-11-26, 02:39:
>Pentium 4 661 3.60 GHz […]
Release price: $401
Release price: $39
I'm willing to buy one on ebay to test this out!
EDIT - A 430 can be obtained for about $13 Canadian on ebay with shipping. The 420 CPU itself is cheap but shipping is like $60+ for the two I can find.
Should I get the 430?
Reply 5 of 64, by rasz_pl
same cpu, just different multiplier lock, mine did 340MHz fsb with 1.45V on GA-965P-DS3. Used it all the way to 2014.
155.72 KiB
Reply 6 of 64, by pete8475
rasz_pl wrote on 2022-11-26, 02:58:
I found a 420 from the same seller as the 430 for the same price so I ordered one. 🤣
I don't know why I do these things sometimes.
Reply 7 of 64, by pete8475
Did some quick playing around with the FSB and so far the CPU seems stable at 4.19.
Noticeable gains in 3dmark05 and UT2003 results.
05 - 10451 3dmarks
UT2003 1280x960
Flyby - 288.409454
Botmatch - 91.150520
EDIT:
Posting from the P4 system here and it seems stable at 4.32GHZ so far.
3dmark01 - 32627
3dmark03 - 51658
3dmark05 - 10718
Aquamark3- 91001
UT2003 1280x960
Flyby - 297.236755
Botmatch - 93.881531
I'll probably try and squeeze a bit more out of the CPU on the weekend but it's getting late tonight and I'm tired.
Reply 8 of 64, by The Serpent Rider
Cedar Mill can go up to 4.5Ghz relatively easy. After that, required voltage rise will lead to quite high TDP, but 5Ghz is totally possible on air.
Reply 9 of 64, by Sombrero
Saying P4 is overkill for WinXP is a bit overkill by itself 😀
Cedar Mills are very speed comparative with earlier P4's, they didn't gain speed during 2004-2006 much at all. My one step below 651 started to get CPU bottlenecked with some games from 2004 with a 9800 GTX+, you are leaving a lot of GPU speed on the table with those kinds of cards.
Reply 10 of 64, by TrashPanda
Sombrero wrote on 2022-11-26, 06:23:
If we are being fair here the 9800GTX+ GPU is a Janurary 2009 GPU so its no surprise that the last of the Pentium4 CPUs cant keep up with it, A better match for the 651/661 would be a 6800 Ultra or a 7800 series GPU, in the OPs case they are simply removing the GPU being a bottleneck from their testing to get a better view of what that P4 can actually do when unrestrained.
That said .. the GT710 they are going to test with .. what a fucking piece of shit ...id rather throw a FX5200 64bit GPU in there than ever touch a GT710.
Reply 11 of 64, by Sombrero
TrashPanda wrote on 2022-11-26, 07:51:
Of course, that's why I've got 6800 GT in there now. I just had the 9800 GTX+ until I found a more suitable card that didn't cost arm and a leg. I also do realise it's just for fun, I was just amused by the whole P4 overkill thing.
Reply 12 of 64, by pete8475
Sombrero wrote on 2022-11-26, 08:23:
Definitely for fun, hence the "silly overkill" title.
I just wanted fastest P4 I could put together without really spending any money.
I was using a 3.06 with 1.5GB of 1066 RDRAM and a Quadro FX3000 for graphics but it irked me that it was unstable with the full 2GB of 1066 memory, so I put together this silly machine to replace it.
Reply 13 of 64, by pete8475
The Serpent Rider wrote on 2022-11-26, 04:40:
That's hilariously awesome.
I will definitely try for more later today.
EDIT - 4500 seems stable so far!
    44.99 KiB
Reply 14 of 64, by pete8475
That 710 ran Excel and Quickbooks very competently for a long time thank you very much. 🤣
Reply 15 of 64, by TrashPanda
pete8475 wrote on 2022-11-26, 15:44:
Dont make me throw a FX5200 at you.
Speaking such heresy.
*I guess it was acceptable under XP.
Reply 16 of 64, by pete8475
4.68 boots into windows with 1.4v vcore, it does bluescreen crash when trying to run anything CPU intensive though.
4.75 doesn't finish booting windows and gets an IRQL_NOT_LESS_THAN_EQUAL bluescreen.
It's so silly having a p4 at this clockspeed, youtube is very usable now! (at 720P, 1080P is a no)
Should I go much higher on the cpu voltage? I didn't play around with these processors much back in the day, don't know what their limits really are.
Reply 17 of 64, by pete8475
TrashPanda wrote on 2022-11-26, 16:04:
heh does it have the 128bit memory? I'll take one of t hose! 😁
Reply 18 of 64, by The Serpent Rider
You can push it around 1.5v safely, if cooler is capable enough. Heat dissipation won't be pretty and you need to stay below 70C.
Reply 19 of 64, by pete8475
The Serpent Rider wrote on 2022-11-27, 15:24:
Well I have fairly chunky tower cooler on there, I'll see what happens with 1.5v!
EDIT:
This is so silly, so far we're up to 4787mhz. 🤣
    45.06 KiB
