First post, by Muz
How do I add Joystick capability for old laptop? Can't find game port attach to it...
Reply 1 of 8, by the3dfxdude
What ports does your laptop have?
Reply 2 of 8, by Muz
Serial port and USB... Toshiba 225 CDS...
Reply 4 of 8, by maestro
I have these but I haven't tested them and I'm not sure if they need drivers or not.
The attachment DSCF9890.JPG is no longer available
Reply 5 of 8, by megatron-uk
In DOS? No. DOS has no understanding of USB at *all* (beyond USB keyboard if your BIOS has 'emulate legacy keyboard support' or some similar setting).
That adapter looks like it will let you use gameport (15 pin) joysticks on systems without a gameport, but you will need a driver for it; I'm 99.99% certain there won't be a DOS driver. If you want to game in Windows, sure, it will probably work - but you'd almost certainly be better off with a simple USB gamepad/joystick at that point.
There are some weird adapters available to let you connect joysticks to the keyboard, mouse or serial ports, but your best bet is the docking station mentioned above - as long as the gameport is exposed on the standard IO ports that games expect (I don't know of many [any?] games that allowed you to change where it looked for the gameport).
https://www.target-earth.net
Reply 6 of 8, by Bondi
A PCMCIA game port is a good solution, if you can find one. (You can check my signature for the list of existing ones).
The best chances is to track down a PCJOY on Yahoo Japan auctions.
There is also this device Notebook GAMEPORT that connects to a COM port. Guess it's limited to real mode games as it requires a driver to work. This one is also not easy to find, though.
The attachment Noteboook Gameport.jpg is no longer available
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
68pins.com custom PCMCIA drivers
Reply 7 of 8, by Zeerex
It’s worth mentioning some non-unobtainium options for OP
Here’s one: can simply purchase the cheapest SNES USB controller on Amazon like https://www.amazon.com/Mafiti-Controller-Joys … y/dp/B079HPDLPC. Within Windows 98 SE this requires no driver, and if DOS games are launched from Windows, it works as a joystick seamlessly.
The other notable alternative is an LPT to SNES which works within DOS using SNESKey - however SNESKey documentation is not good and takes some figuring out. Works well on a Pentium 233mhz laptop I have but it’s too slow on a Pentium 75mhz (libretto 50CT) so I’m not sure how it will perform on a P133 like OP’s Toshiba. These were usually available on this site, https://www.raphnet-tech.com/products/snes_co … rport/index.php, but unfortunately out of stock however the schematics are openly available should one choose to build one.
Reply 8 of 8, by kiacadp
Have you considered Volo's Gamepad to PS/2 adapter?
