First post, by Ozzuneoj
As I look at my PC collection and think back on any that I have seen or had in the past, I have realized that I've never seen an AT Form Factor tower that didn't have a gigantic metal cover that must be slid\lifted off all at once and then set somewhere when the PC is being worked on. I've never seen one with separate removable side panels. 😮
So, I'm calling on the diverse collections of you VOGONS users here... does such a thing exist? If so, how common are they?
I know that an AT board can go in an ATX case with the right (or no) I/O shield as long as it has the right mounting holes... but that's simply backward compatibility and isn't what I'm talking about.
What I'd like to see is a case that is truly an AT-only style with a permanent DIN keyboard hole, no way to mount an ATX board and a mounting location for an AC power switch\button.
Also... pics or it didn't happen. 😁 😁 😁
Reply 1 of 14, by Doornkaat
Those towers designed by Luigi Colani for Vobis have individual side panels.
Too lazy to attach a pic. Just google 'Colani tower'.
Reply 2 of 14, by Ozzuneoj
Doornkaat wrote on 2023-02-03, 03:41:
Wow... that's quite a tower! Looks like they're ridiculously expensive when they show up too. 🤣
I wonder if there are any others out there?
Reply 3 of 14, by Intel486dx33
I have one on my 486 build
See my post:
486 Multimedia dream build ( 1993/94 )
Techmedia was a computer builder company from Silicon Valley back in 1990’s
This case I think is actually for a 1st gen pentium motherboard but I am using it for my 486 build.
Techmedia designed their own computer cases.
This is a really nice case too.
It’s very heavy as it is made of thick gauge sheet metal. And it has a thick coat of paint too.
One of the nicest AT tower cases I have ever seen.
Reply 5 of 14, by dionb
I have one, a grey case used for an industrial PICMG backplane and SBC. Probably dates from early 2000s (the SBC was the original one, and was Tualatin-supporting So370).
Reply 6 of 14, by Ozzuneoj
Wow, they do exist! Thanks guys!
So you'll agree this isn't something you find every day then? I need to keep my eyes open for one. I'm not sure if I would have even thought about it before now so I may even have passed one up at some point.
Reply 7 of 14, by dionb
Rare as hen's teeth, and most likely from the very end of AT case production.
Probably industrial/rackmount cases are your best bet.
Reply 8 of 14, by MMaximus
The Colani tower indeed had separate side panels but there were other cases from Vobis as well - I used to own one back in the day and made a thread about it not long after I joined vogons 8 years ago 😅
The attachment gettyimages-875825320-594x594.jpg is no longer available
Hard Disk Sounds
Reply 9 of 14, by RandomStranger
I just found this.
Reply 10 of 14, by Ozzuneoj
Wow, another nice one! Is that fake-floppy 5 1/4 drive bay cover at least removable? It almost looks like it's part of the case. 🤣
I have never seen any of these before.
Or any Vobis computers for that matter.
Reply 11 of 14, by BitWrangler
If you want real easy tinker access, lemme ruin your life by telling you about the unicorns with a hinged flip up panel like the hood of a car. Mostly lie flat desktop format. Horrible for ventilation too, you don't want many watts in most of them (i.e. 233MMX and below)
I saw a fat squat minitower AT some long while ago with a case badge from some cheeky buggers calling themselves "Com-Pac", sold with a P100 in on an FX board to give an idea of dating, but no idea who made the case, seemed generic, but higher end generic.
I think some Dells had that style, but they were between early pentium and jumping on the ATX train early, so a year of them at most. Also Acers had them longer, but they were doing this weird halfass ATX thing with ATish ATX style 3.3V power and power management and I had doubts about whether they were really AT cases, soft power buttons, weird PSUs. I had managed to replace a failed board in one with a baby AT board, but it took matching the dimensions close.
edit: this one appears to have panels, not sure the store either has stock or is good to deal with, but maybe the part number turns up elsewhere https://baber.com/cases/mpe_md59.htm
Reply 13 of 14, by Errius
I guess the all-in-one case cover design was cheaper. I had an ATX case like this and it was very annoying to reassemble. This design is not practical with very large cases though.
"AI Requires Proof That You Are Human"
Reply 14 of 14, by Ozzuneoj
BitWrangler wrote on 2023-02-03, 23:58:
Oh man, I forgot about those Acers! Now that I think about it, I might actually have one of those in my garage!! I was given a gray colored Acer tower from like 1995 and it was partially disassembled. I think I have the original mouse and keyboard for it as well. It is probably something similar to AT... but I can't remember how the case opens. I think I eventually found all of the parts of the tower itself to reassemble that, but it has been a "future project" for ~3 years so I haven't looked too closely at it.
EDIT: Pretty sure the one I have in the garage is like this...
https://www.reddit.com/r/vintagecomputing/com … pire_from_1995/
https://www.worthpoint.com/worthopedia/acer-a … dows-1956480113
Ahhh... just found this picture. It's probably not AT then unless they did some different versions of this tower.
https://imgur.com/gallery/G2KAZVF
Just found this ad for one too... 🤣
The attachment acer_aspire_ad.jpg is no longer available
What were they thinking mashing two different paragraphs\lists together on the side? Ah, '90s advertising...
