First post, by britain4
Afternoon folks - hopefully a quick one, purchased a CT4380 AWE64 card off eBay as “PC won’t boot when inserted”. Normally wouldn’t pay much for anything with an unknown issue like this but I could see physical damage to the card in the photos that looked like an easy fix.
Turned out that meant a dead short on the 5v rail and the computer not powering on at all, but numerous trace repairs later, and the removal of a shorted cap, and it lives!
Only issue now is that R101 is still missing - it’s an SMD resistor connected to the top DRAM header J1 - would anyone be so kind as to let me know what value this is, as I can’t find a service manual or high-res board scan (unless I’m missing something in which case sorry!)
Anyone have any experience expanding the RAM on these card, either on-board or where I might find a suitable daughter board? SIMMConn still the best/cheapest bet?
Thanks!
- P-MMX 200MHZ, PCChips M598LMR, Voodoo
- P-MMX 233MHz, FIC PA2013, S3 ViRGE + Voodoo
- PII 400MHz, MSI MS6119, ATI Rage Pro Turbo + Voodoo2 SLI
- PIII 1400MHz, ECS P6IPAT, Voodoo5 5500
- Toshiba Libretto 110CT, 300MHz, 96MB RAM
Reply 2 of 2, by britain4
Awesome thank you 🙂
