First post, by informatyk
How to add DVD UDF support for windows 98?
I have already tried https://www.roxio.com/en/support/software-updates/udf/ but it gives me an error "The roxio UDFReader has not been detected".
https://download.marpio.net IE4 compatible retro software download site
Reply 1 of 6, by akula65
Did you reboot after installation? Some software requires it.
Reply 2 of 6, by informatyk
I can't even install it, because it gives me following error (its Win10 but the same on win98).
Reply 4 of 6, by informatyk
You're right. I found the driver, installed but the DVD-ROM disappeared from the windows after reboot. It isn't present in device manager.
Reply 5 of 6, by dormcat
What's the make and model of your DVD-ROM?
Reply 6 of 6, by informatyk
It's SAMSUNG SD-608. After another reboot it is recognized in Windows again but as AudioCD which is nonsense.
I used Adaptec UDF Reader Driver 5.1.1.213
EDIT: Problem solved. I changed Samsung DVD to newer one (from 2004) and now it works!
