Missing libcaca.so.0:
First post, by texashuman
I purchased an Acer Chromebook Vero 514 - CBV514-1H-55VP
Activated LINUX Debian Buster 10
I have managed to do a Flatpac install of the 2.7.0 Heroic Games Launcher and it seems to work since I was able to log into both my Epic and Gog accounts.
I seem to have been able to download Master of Orion II From GOG since all the files are in my games folder.
But, the game will not launch.
As I read the report, I didn't get a complete DOSBox with the download??
Looks like I need libcaca.so.0:
If it is available, can I simply paste it into the file /home/daviwaynedisney/Games/Heroic/Master of Orion 2/dosbox/dosbox_x86_64 ?
Thanks
System Info:
Heroic Version: 2.7.0 Eustass Kid
Legendary Version: 0.20.32 Dark Energy (hotfix #6)
GOGdl Version: 0.7.1
Electron Version: 23.1.4
Chrome Version: 110.0.5481.192
NodeJS Version: 18.12.1
OS: Freedesktop SDK KERNEL: 5.15.89-16173-ge924d337a40c ARCH: x64
CPU: Intel Gen Intel® Core™ i5-1235U @2.5
RAM: Total: 6.35 GiB Available: 2.29 GiB
GRAPHICS:
PROTOCOL:
Launch Command: /app/bin/heroic/resources/app.asar.unpacked/build/bin/linux/gogdl launch "/home/daviwaynedisney/Games/Heroic/Master of Orion 2" 1207661633 --platform linux
Game Log:
Running Master of Orion 2
Starting DOSBox
/home/daviwaynedisney/Games/Heroic/Master of Orion 2/dosbox/dosbox_x86_64: error while loading shared libraries: libcaca.so.0: cannot open shared object file: No such file or directory
Done.
Launch command: ['/home/daviwaynedisney/Games/Heroic/Master of Orion 2/start.sh']
All processes exited
Reply 1 of 18, by DosFreak
Thus forum isn't free support for gog. If you bought it from there you should get support from there. It's likely you wouldn't be the only one with the issue and they may already know the solution for the missing dependency which would be to use a build of dosbox provided by the repo for your distribution or to install the missing dependency for the build you are trying to use.
Make your games work offline
Reply 2 of 18, by texashuman
I AM looking for a source for the missing dependency.
Reply 3 of 18, by jmarsh
That isn't a regular dependency for DOSBox, it seems to be something specific to the build supplied by GoG so take it up with them.
Reply 4 of 18, by texashuman
Ok. Thanks.. That was a bit of information I needed to know.
It is interesting though that I have the same game downloaded from GOG on a Win 7 Ultimate machine and a Win 11 Pro and that dependency is not in either of them so If it is a GOG issue, it is specific to what they are offering for Linux.
So far I am getting crickets on the GOG support forum.
Reply 5 of 18, by elszgensa
> GOG support forum
Ah, there's your problem. Their forums are discussion forums, and clearly labelled as such; any support still happening there is purely coincidental. The support section's thataway.
Another approach would be to ignore their bundles DOSbox version (do keep their config files though), install one through your package manager and use that. I doubt they invest a lot of manpower into customizing the code of the app itself so you should be fine. Of course you're on your own then wrt support.
Reply 6 of 18, by texashuman
Ok. Thanks for the ideas.
I cannot get through the GOG support maze because I am not actually using a Ubuntu distro. I am using Debian 10 Buster.
I am going to keep looking for libcaca.so.0: and paste it in where it is supposed to be.
This problem has been cropping up with other GOG games and also some Steam games.
Or just wait till GOG does an update.
Reply 8 of 18, by wbahnassi
Rather disgusting... He intentionally named it like that.. in fact his github account is all about the same.. well.. smelly thing. 🤢
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 9 of 18, by dougdahl
So when you try to use
sudo apt-get install libcaca0
(note the last letter is a zero)
the libcaca.so.0 doesn't work?
Reply 10 of 18, by texashuman
dougdahl wrote on 2023-04-29, 07:28:
So when you try to use […]
I am not a linux aficionado so I had no idea I could even do such a thing. Will give it a try.
Reply 11 of 18, by cde
cyclone3d wrote on 2023-04-29, 02:13:
I just stopped by to say that libcaca.so.O is a super funny name.
To clarify the joke, "caca" means poop in French. It's a bit immature 😀
Reply 12 of 18, by elszgensa
Poop jokes are acceptable, even well received, but when somebody names his code "libupskirt" then there's a shitstorm? Okay.
Reply 13 of 18, by texashuman
wbahnassi wrote on 2023-04-29, 03:09:
His who??
Reply 15 of 18, by wbahnassi
texashuman wrote on 2023-04-29, 14:59:
His who??
Maker of that lib. It's a code library for colored ascii art generation.
Reply 16 of 18, by leileilol
elszgensa wrote on 2023-04-29, 14:17:
funny waste euphemisms != sexual harrassment
long live PCem
Debian's fucked
Reply 18 of 18, by dougdahl
texashuman wrote on 2023-05-13, 20:05:
https://drive.google.com/file/d/1HjF7p_o8Q_qe … ?usp=share_link
Didn't work.
You need to run apt-get not get-apt.
