Troubleshooting two Slot 1 Asus motherboards
First post, by mrfusion92
I knew that this post would have been necessary.
So I bought an Asus P2B and a P3B-F. Sold as unkown working status. They arrived yesterday.
And... of course they don't work.
The P2B was easy to diagnostic. The MOSFET in Q10 is missing on the top. Yeah I didn't notice in the seller photos.
Does anyone know the exact component?
The P3B-F is whole another story. It doesn't do anything with the CPU plugged in, not even a beep.
The attachment PXL_20230602_142034915.MP.jpg is no longer available
With the CPU removed the speaker does a reapeating pattern of LOW and HIGH beeps, which means and I quote "Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat. Check the CPU fan or BIOS settings for proper fan speed."
What I have tried so far:
  • two PII 350Mhz CPUs. Tested also JumperFree mode.
  • different RAM modules or none at all.
  • two know good PSUs.
  • flashed different BIOS versions. Now there is this one.
  • new CMOS battery.
  • cleaned CPU slot edge connector.
Another maybe interesting detail, I tried still with a video card and my KVM switch doesn't turn on at all. That KVM even without a proper video signal it turns on when it is plugged to a powered on video card.
I don't see any physical damage but I know that caps can go bad without any visible defect. Before going down the road of recapping the full thing, is there something else that I can check?
I know that they are really good motherboards (when they work) so I really want to try to get them fixed.
The attachment PXL_20230602_142229359.jpg is no longer available
The attachment PXL_20230602_142224928.jpg is no longer available
Reply 1 of 38, by Zerthimon
Try this: set the jen jumper to a jumperfree mode, then connect only the CPU, power it on, then after one minute check if anything is getting hot on the board (both bridges, Asus (monitoring) chip, winbond (sio) chip) etc.
Reply 2 of 38, by mrfusion92
I am speechless...
I was doing what @Zerthimon said, while touching around all the chips... the motherboard started POSTing under my eyes.
Powered off, plugged RAM and video card.... and I was able to go to the BIOS and even boot my bench DOS CF card.
The attachment PXL_20230602_152708156.jpg is no longer available
The attachment Screenshot 2023-06-02 17-26-54.png is no longer available
I think it started POSTing after I touched\pushed this chip, which I think is the clock generator. It also gets hot, is it normal?
No other chips got too hot, only that.
The attachment PXL_20230602_151726652.jpg is no longer available
Reply 3 of 38, by Zerthimon
Yes, that's the clocker chip, and it should get warm, but not mad hot.
Reply 4 of 38, by bogdanpaulb
I think the caps are failing, when they are somehow bad and the board was not powered for a long time, they need some 'warm up' time.
Reply 5 of 38, by mrfusion92
And indeed after a couple of hours while I left the motherboard disconnected I'm back to square one with zero signs of post.
The clock chip gets very hot, I can't leave my finger on it more than 3 seconds. This also while it was working.
I'm not so good with the desoldering. Like I did a small recap in a Pentium 4 motherboard, it works now but desoldering the caps was a nightmare for me.
Reply 6 of 38, by verysaving
Try replacing the tiny smd cap near the clock generator.
Bigger caps seem to be Rubycon and Sanyo and they age
usually well if not thermal stressed.
Reply 7 of 38, by mrfusion92
Basically now it's a diesel engine, it needs 5/10 minutes to warm up then it boots 🤣
But I've noticed this now, it gives me this hardware error which I've ignored so far thinking it was because of the missing floppy disk drive .
The attachment Screenshot 2023-06-03 09-22-47.png is no longer available
And the error is about the 12v rail. I disabled the monitoring of it and the error got away. Tested two PSUs and reading was about the same. The voltage read out got from a molex with a multimeter is in spec.
How can I know which caps are on the 12v rail?
The attachment Screenshot 2023-06-03 09-19-34.png is no longer available
verysaving wrote on 2023-06-03, 00:41:
Oh god that tiny little cap? If I try to remove it I will end up ruining this motherboard even more. Besides I can't understand the values of it.
The attachment PXL_20230603_070028873.jpg is no longer available
Reply 8 of 38, by Horun
Appears to be a Panasonic Alumimum cap. 10uF 16v SMT. The 10 is for 10uf, CFC is voltage/series. first letter is voltage, C for 16v, FC is the series. Bottom stuff is the lot.
From this pdf: https://www.farnell.com/datasheets/2813661.pdf and this for a 10uF 50v: https://ph.rs-online.com/web/p/aluminium-capacitors/0568777
Reply 9 of 38, by ediflorianUS
Congrats on fixing(to P.O.S.T) . I wanted to suggest setting the MB jumpers manually , because I had better luck doing everything manually.
P.S. instead of changing SMD caps (if they are not in short) try just cleaning them with electronic contact cleaner (I Use italian DUECI Electronic)
My 80486-S i66 Project
Reply 10 of 38, by verysaving
When the MB is cold, try heating the caps with a hair dryer
and see if it boots up.
Reply 11 of 38, by shevalier
mrfusion92 wrote on 2023-06-03, 07:37:
#1 Never try to desolder the SMD electrolyte.
#2 Never try to solder smd electrolyte without heating from below.
Use SMD tantalum capacitors or MLСС
Hint
You should collecting non-working hardware.
For example, Radeon 9xxx, which does not work, not only look good on the shelf, but also serve as a source of SMD tantalum capacitors 10-22uF 6.3-16V.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 12 of 38, by mrfusion92
shevalier wrote on 2023-06-04, 04:06:
#1 Never try to desolder the SMD electrolyte. #2 Never try to solder smd electrolyte without heating from below. Use SMD tantalu […]
Hint
I do have a Radeon 9200 which shows artifacts with probably bad vram chips! And indeed seems to have three 10 uF caps but I think that they are rated for 16v. Is that an issue?
The attachment PXL_20230604_133652858.jpg is no longer available
However, the fact remains that I am not equipped for this type of work. I will probably need at least an hot air gun.
Reply 13 of 38, by shevalier
mrfusion92 wrote on 2023-06-04, 13:45:
This will show only the replacement
You can't solder them with a soldering iron, see picture.
Hot air gun - overheating.
Finally use MLCC, the 21st century is ending...
Reply 14 of 38, by shevalier
Or tantalum capacitors, in a pinch
Reply 15 of 38, by bloodem
Wut?
Wut?
shevalier wrote on 2023-06-04, 15:02:
Again... wut?
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 16 of 38, by shevalier
Everyone says WUT.
But not everyone shows results.
The photo shows a complete reflow of solder at the factory, and not 1 mm of snot.
Reply 17 of 38, by Roman555
mrfusion92 wrote on 2023-06-02, 22:31:
A good clock generator can be very hot. Usually if it isn't warm at all then it doesn't do its job. So I wouldn't pay attention to its hotness.
What about that little capacitor - try to add an usual (not smd) electrolytic capacitor in parallel to it. Just don't confuse where + and - pins. To diagnostic matter I wouldn't even solder it. I think it is easier than replace the smd cap.
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 18 of 38, by Doornkaat
bloodem wrote on 2023-06-04, 15:29:
Wut? […]
Wut?
Wut?
Again... wut?
I'm also confused. Regularly soldered SMD electrolytics with a regular iron withput preheating the board or anything. No issues so far.🤷‍♂️
Edit: Are you by any chance not using flux or are you using an iron with too low temperature, shevalier?
Reply 19 of 38, by mrfusion92
Setting aside the technique to solder. I'm writing the shopping list of caps to buy, and I will replace all of them. The through hole ones and also the other SMDs.
I have cross-checked with this webpage. That part list is for the rev 1.03, mine is the 1.04 and there is only one 100 uF cap more. All the others are exactly the same.
That page doesn't mention the smd caps, which are 5 in total and are all the same like the one near the clock chip.
I'm just unsure which type of smd caps I should buy. MLCC seems to be easy to solder and I've found this, is it correct? The size too?
Otherwise I've found this that seems to be a "drop-in replacement".
Roman555 wrote on 2023-06-04, 17:30:
I have only some ceramic 100uF caps from a small electric project I was doing. I don't think I can use them for test. Besides today it is behaving way better, it failed only the first boot. I will leave it disconnected the whole night and see if tomorrow morning it will be dead.
