First post, by envagyok
I have a thinpad 370c notebook with dock I (3545)
which has only one isa slot and stereo speaker.
I put in already a Soundblaster Pro II CT1600, which is good for opl, sb, sbpro, but no daughterboard, and midi capability.
I need advice what is the best one card solution (except for new orpheus, etc) for compatibility and sound quality for most DOS Games.
What i have this moment:
CT1350 SB , CT1600 SBPRO2 , SB16 many CT1740 too, AWE32 , AWE64 value and Gold, Yamaha SW20PC, SW60XG, Audician, miro pcm10, some aztech, and Opti, gravis classic, and pnp
Daughtercards: db50xg, orchid, terratec, ct1920
Thanks every hint
Reply 1 of 12, by Pierre32
Trying to find the best single sound card for DOS will drive a man to drink 😁
But you have a nice range of choices. Personally I would go for the Audician for its great compatibility, real OPL and bug free MIDI.
Reply 2 of 12, by Trashbytes
Pierre32 wrote on 2023-06-18, 09:47:
You can even do the mods to the Audician to fix the reversed stereo channels IIRC there is also another mod to fix the mixer too, doing these mods and combining the card with a Dream Blaster X2GS or a Dream blaster X16GS would make it pretty much a perfect DOS sound card.
Or you could throw the SW60XG in there and use it as the MIDI device, then you free up the gameport on the Audician for a joystick. (Just realised this is for a single ISA slot so the Audician modded on its own is still a solid choice + you could also look into a MT32 or SC55 for external midi)
I run a modded Audician + X2GS in my DOS rig and its ran every game I have thrown at it with zero sound issues, its a solid choice.
AI is inevitable, there is nothing you can do to stop it, no Ironman snap to save you from the Basilisk.
Reply 3 of 12, by envagyok
Seems good 😀
Reply 4 of 12, by envagyok
That's the way think to connect to yamaha audician a db50xg, because with my thinkpad i dont want to move my roland sc-55.
At home i have a 486dx2+sb pro2+gus classic+midi din out card for sc-55, and another pc for later dos games.
Reply 5 of 12, by Trashbytes
envagyok wrote on 2023-06-18, 13:22:
The issue might be enough space, usually these base stations only have just enough to accommodate the card, but if there is room for the daughter card along with the Audician then that would be a good option too.
Reply 6 of 12, by envagyok
I will try 😀
Reply 7 of 12, by Bondi
Trashbytes wrote on 2023-06-18, 14:17:
That's not an issue. I have an IBM Dock I and can confirm that it can accomodate a full length card with a daughterboard.
I'm using mine with a generic ESS 1688 based card with a Dreamblaster X2 and couldn't be happier with it 😀
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
68pins.com custom PCMCIA drivers
Reply 8 of 12, by badmojo
The only problem with the Audician is that it's a half height card, so a big DB like a DB50XG won't fit. You can use a ribbon cable but that gets messy.
The X2GS fits it though of course and is a great option.
Reply 9 of 12, by envagyok
Trashbytes wrote on 2023-06-18, 10:22:
Where can i find information about this mods?
Reply 10 of 12, by Joseph_Joestar
envagyok wrote on 2023-06-20, 01:20:
In this thread by James-F.
There are three things that you want to do with a YMF71x card. Adjust the mixer settings, restore the low-pass filter and fix the wavetable header. The first one is a simple software tweak, while the latter two are hardware mods. It's well worth it though, and the YMF71x becomes one of the best DOS sound cards after all that.
My retro stuff
Reply 11 of 12, by badmojo
Joseph_Joestar wrote on 2023-06-20, 02:55:
... and fix the wavetable header.
Just a comment on that one - if you have a Dreamblaser X2 (or X2GS and probably other Dreamblaster boards) then you can reverse the stereo output with the provided config software. Easier than a hardware mod.
Reply 12 of 12, by envagyok
I make yesterday this mods, thank you.
I will make cable for db50xg, this moment use with terratec mifi daughtercard.
