First post, by Soulreaper
This has been quite the journey for a few years. I am always having sound card issues recently I decided to do a randomizer game pick. Kyrandia book one was picked I installed it, and crashes when speech starts. I found if I left the digitized sound to no sound card I can play the game but I want to hear the voice acting. So I scoured the forums and didn't find much for a resolution other than try wdm drivers. So I gave it a try and no fix but I thought I haven't ever tired these drivers on my machine and found that the uart output on the sound blaster actually works now without issue with my sound canvas. So next I thought maybe this has fixed the midi duke 3d issues I am having. I could never get the midi to work I would always get an mpu401 not detected error ever time I tried to run any build engine game. Well now it works also the pci echo crash bug is not a problem anymore . But I have found when testing sound in the duke3d setup stereo does not work. When the pool balls are played the center channel works but then when the left and right channels are played the sound is slightly quieter but played on both channels. I tried a few different revisions of the wdm drivers and they all do the same. Then I tried the vxd driver I had before to verify I wasn't crazy and indeed the stereo works. Has anyone come across the wdm driver breaking stereo in duke 3d. Is there a work around?
98se/Biostar M7VIG Pro/AMD Athlon XP 2400+ @ 2.0 GHz/512 MB @ 166/ATI Radeon 9800 Pro/3DFX Voodoo 3 2000/CreativeSBLive!
XP Pro/Asus P5N-D/Intel Qx9650 Quad Core@4.0GHz/4GB DDR2 800/nVIDIA GeForce 9800 GTX+ SLI/Creative Audigy 2 ZS
sc-55 mkii
Reply 1 of 5, by Warlord
I thought you had to use the VXDs, becasue the WDMs didn't work.
Reply 2 of 5, by Soulreaper
I am on win 98 se and wdm drivers are working quite well I have only tested doom and duke 3d so far. I thought that too thats why I have never even tired them but when I found the suggestion to use wdm drivers to fix kyrandia I gave it a shot.
sc-55 mkii
Reply 3 of 5, by Joseph_Joestar
Soulreaper wrote on 2023-07-30, 04:45:
If I remember correctly, the Live's VxD drivers are SB6 compatible while its WDM drivers are only SBPro compatible.
In Duke3D setup, make sure that you've selected Sound Blaster Pro 2.0 for digital sound, and see if that helps.
Reply 4 of 5, by Soulreaper
I'll try that now I do think I did try all options it was late then though.
sc-55 mkii
Reply 5 of 5, by Soulreaper
Cheers that did it I guess I skipped over sound blaster 2.0 (new). That was the winner. Now back to kyrandia I have decided that I may need to use scumm vm on my other machine. But if any thoughts to fix that problem would be helpful. I tried to use cpu grabber, cpu slowndown, and a ram disk thinking that my hardware was op. but it works when disabling digitized sound so I guess it has to do with the sound card.
sc-55 mkii
