First post, by alexparr
The motherboard I ordered for that 486 project I mentioned a couple weeks ago finally arrived. I can't use it right now–mainly because I can't buy that power supply yet–but something I'm not sure of is the model.
The seller mentioned in the listing title that it's a "Jetway PV1.0", but searching that up brings me no results–other than the original listing itself. The bottom of the board also claims that it is a "TMF M21 94V-0", though as far as I can tell that's just some generic thing they used on a few motherboards, and none of the results I found matched my board.
Can someone help me identify this thing? I'm asking mainly because I want the jumper settings for this thing, in case I ever want to install a i486DX4-100 at some point. Here's some photos of the board:
Gateway 500S:
OEM Intel D845PT
Pentium 4 @ 1.80 GHz
256MB RAM
GeForce4 MX 440
SoundBlaster Live! CT4780
CAPS MAY HAVE FAILED, NEEDS MAINTENANCE
486 Project:
Jetway Motherboard
i486DX2 @ 66 MHz
8MB RAM
S3 Virge/DX
CURRENTLY OUT FOR REPAIRS
Reply 1 of 18, by rasz_pl
alexparr wrote on 2023-08-05, 01:26:
Those are usually PCB (not motherboard, just the pcb house) manufacturer markings. 94V-0 means PCB is non flammable https://en.wikipedia.org/wiki/UL_94 . Im gonna guess TMF is board house and M21 code for particular process.
This very well might be some Jetway, https://theretroweb.com/motherboards/5506 looks related with very similar layout/print
in fact https://theretroweb.com/motherboards/s/jetway-j-437 has same board house "TMF M21 94V-0" markings
Reply 2 of 18, by PC Hoarder Patrol
Can't see an exact match, so sadly no help with the jumpers, but from the partial listed string ID 2A4UKJ11-00, it does seem to have a Jetway BIOS - maybe PV1.0 is a version number
Reply 3 of 18, by alexparr
rasz_pl wrote on 2023-08-05, 10:44:
Good to know; it makes sense that I see it on a ton of motherboards.
Interesting. I wonder if this is a rare variation of some kind?
PC Hoarder Patrol wrote on 2023-08-05, 11:05:
... from the partial listed string ID 2A4UKJ11-00, it does seem to have a Jetway BIOS - maybe PV1.0 is a version number
That could very well be the case, though I have no way of verifying it currently.
Gateway 500S:
OEM Intel D845PT
256MB RAM
GeForce4 MX 440
486 Project:
Jetway Motherboard
i486DX2 @ 66 MHz
8MB RAM
S3 Virge/DX
Reply 4 of 18, by mkarcher
alexparr wrote on 2023-08-05, 20:52:
Your model is the direct successor. Jetway replaced the 4 30-pin sockets by a single 72-pin socket (this is functionally equivalent), and replaced 3 ISA slots by 4 PCI slots (using the space gained by abandoning the 30-pin sockets). To operate the PCI slots, a 486 local bus to PCI bridge had to be added, too. This looks like a standard "we update our board for PCI support" approach to prolong the life time of that board design. "PV" sounds like "PCI + VL", and this is likely to be Jetway's first PCI+VL mainboard, as it is very similar to the non-PCI version, so it would make sense that your board would be called "PV1.0" internally. I just found that the older Jetway board was also sold under the Edom/WinTech and Lucky Star brands (https://theretroweb.com/motherboards/s/edom-w … ech-mv035-rev.c), so it looks like these boards are generic OEM boards, but your OEM board seems to be a less common one.
Reply 5 of 18, by alexparr
mkarcher wrote on 2023-08-05, 22:35:
Interesting. It seems like a few other things were moved around too, like the jumpers; which is in no way helpful to me whatsoever.
I just found that the older Jetway board was also sold under the Edom/WinTech and Lucky Star brands (https://theretroweb.com/motherboards/s/edom-w … ech-mv035-rev.c), so it looks like these boards are generic OEM boards...
If that's the case, then I wonder if it's possible to find the board I have under a different brand? If so, then perhaps the way the jumpers are laid out are identical as well.
Gateway 500S:
OEM Intel D845PT
256MB RAM
GeForce4 MX 440
486 Project:
Jetway Motherboard
i486DX2 @ 66 MHz
8MB RAM
S3 Virge/DX
Reply 6 of 18, by Horun
I never fully understood the J-Mark to Jetway connection, both archives list same boards (but not this one). Any ideas ?
Reply 7 of 18, by rasz_pl
I have a feeling those two entries should be linked, its clearly same board ;o 😀
Reply 8 of 18, by weedeewee
rasz_pl wrote on 2023-08-06, 07:56:
different revision though, D2F vs D2C. though, good luck spotting the differences 😀
Do not ask Why !
Reply 10 of 18, by mkarcher
alexparr wrote on 2023-08-06, 00:04:
Exactly my thoughts. I tried a generic google image search like "opti 486 pci mainboard", but I couldn't find any references.
So I guess that possibly the three-chip solution (Opti 895/602 + 822 PCI bridge) proved to not be as cost effective as a 2-chip solution like the SiS 496/497. As designing a mainboard based on a different chipset takes some time, the Opti PCI board you have might have been intended as "gap filler" to provide PCI until the boards with northbridge-integrated PCI were available.
Reply 11 of 18, by majestyk
The capital letter on the AWARD BIOS chips with white paper labels can tell the mainboard manufacturer.
"D" is for Abit
"F" is for FIC
"E" is for Chaintech
"I" is for Aquarius Systems
"J" is for Jetway
Please note that the letter only occasionally corresponds with the first letter of the brand name.
I wonder if someone has a complete list of those codes?
Reply 12 of 18, by evasive
majestyk wrote on 2023-08-06, 16:11:
The capital letter on the AWARD BIOS chips with white paper labels can tell the mainboard manufacturer. "D" is for Abit "F" is f […]
"D" is for Abit
"F" is for FIC
"J" is for Jetway
Pleas note that the letter only occasionally corresponds with the brand name.
It is the first time I hear of this.
I noticed several of these on EPoX boards but there they are revision stickers.
Reply 13 of 18, by evasive
Horun wrote on 2023-08-06, 02:17:
J-Mark was the brand that Jetway board were sold under in the U.S. of A.
Reply 14 of 18, by Horun
evasive wrote on 2023-10-28, 21:01:
Thanks, that makes sense
Reply 15 of 18, by alexparr
Adding back on to this, I found another Jetway motherboard that seems very similar in terms of its' features: https://theretroweb.com/motherboards/s/jetway-j433-a
The biggest difference that I can spot is that instead of 4 PCI slots and 3 VLB slots, we have 3 PCI slots, 2 VLB slots and an integrated controller card, and there's also a PS/2 mouse port (?).
Oh yeah, and it uses a VIA chipset instead of an OPTi one.
Gateway 500S:
OEM Intel D845PT
256MB RAM
GeForce4 MX 440
486 Project:
Jetway Motherboard
i486DX2 @ 66 MHz
8MB RAM
S3 Virge/DX
Reply 16 of 18, by majestyk
They say it´s not best prctice to place the cache banks between CPU and VLB slots, because the longer traces might decrease stability at 40 / 50 MHz.
Reply 17 of 18, by quicknick
alexparr wrote on 2024-02-01, 23:18:
...I found another Jetway motherboard...
Did your board come with a CPU and if so, which one? I'm interested in the jumper settings, because I got an identical one that came without CPU and I'm unable to make it perform at least half-decent with the few CPUs that I tried.
Reply 18 of 18, by alexparr
quicknick wrote on 2024-02-03, 22:27:
I probably should've clarified; I don't have this motherboard, I'm just saying that I found this motherboard on the website and noticed that its' featureset is similar to the motherboard I do own.
Gateway 500S:
OEM Intel D845PT
256MB RAM
GeForce4 MX 440
486 Project:
Jetway Motherboard
i486DX2 @ 66 MHz
8MB RAM
S3 Virge/DX
