First post, by avatar_58
Don't mind me, I'm setting up every dos game I can find and some errors come to surface...I'm only trying to help 😊
In Alone in the Dark 2 & 3 the setup program does not show up correctly. The buttons are moved and impossible to hit making sound setup really hard:
    29.18 KiB
Reply 4 of 11, by vasyl
Interesting, the buttons text moved half-way up the screen. This is symptomatic with that Lode Runner bug that I've fixed last night. The patch is in Sourceforge but did not make through to ykhwong's build yet. If you can compile DosBox I would suggest trying with that patch.
Reply 5 of 11, by avatar_58
My machine isn't exactly setup for compiling....and I wouldn't begin to know where to start 😅 Hence why I use builds... 😢
The best I can do is ask you to try or send you the setup (for testing purposes of course)
Reply 10 of 11, by POLE
I got more or less the same problem. I have all the original trilogy in CDs and the dos installation simply hangs on that screen. I must install it on windows to make it work. On a side note, the install program (which allows to change the options for the sound hardware) works like a charm and the games works.
My version is DOSBox 0.65.
Is there a workaround for this?
P.S. I am not english native so there could be mistakes.
