First post, by ppgrainbow
I'm having problems getting MS-DOS 6.22 to recognise my SanDisk 2 GB Ultra CF card (model number: SDCFH-2048) on my Toshiba Tecra 500CDT laptop. The laptop has the Toshiba ToPIC95 CardBus controller chipset.
When I performed a surface scan of the compact flash drive using SCANDISK, the surface scan stops at cluster 4 and hangs until I eject the card. Also, when I also tried to copied a bitmap file (AITANA.BMP), I end up getting a Sector Not Found writing drive D error.
I used a PNY Optima 1 GB compact flash card and it works fine without problems. It seems that the SystemSoft CardWizard software has problems attempting to properly recognise compact flash cards above 1 GB - which weren't available at the time when it was released in mid-1996.
Here are the screenshots of the issue that I provided below:
377.58 KiB
366.49 KiB
I must apologise for the bad screenshot, but this came from my AT&T Calypso 3 phone while I was taking pictures of the issue.
Are there any other PCMCIA drivers that I can try to overcome the 1 GB limit? I tried the CardBus Enable utility (CBENAB.EXE) and it recognise the 2 GB CF drive and it seemed to work. I hate having to pay more money, plus shipping and handling just to download a compatible PCMCIA driver!
Here are my CONFIG.SYS and AUTOEXEC.BAT files for reference:
CONFIG_SYS.txt
1.08 KiB
36 downloads
AUTOEXEC_BAT.txt
389 Bytes
32 downloads
Reply 1 of 14, by Bondi
Hey ppgrainbow. There are two main software packages for PCMCIA support, which are Phoenix Card Manager and Systemsoft Cardsoft. However, I'm not sure they support that Toshiba ToPIC95 chip. Worth giving a try the latest versions of both.
You can download the softrawe on archive.org in the link in my signature.
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
Reply 2 of 14, by ppgrainbow
Bondi wrote on 2023-12-28, 07:43:
I'll try the Phoenix Card manager to see if it works under MS-DOS and I'll get back to you with the results! 😀
By the way, does anyone have a link to Phoenix Card Manager 4.02? It comes in two 1.44 MB diskettes and I can't seem to find it. 🙁
Reply 3 of 14, by lolo799
Cardsoft 5 supports the ToPic95 chip.
Note that in the Toshiba bios you can switch between 16bit pcmcia and Cardbus mode.
CardWare, from the same company that made the CBENAB and others pcmcia enablers, supports the chipset and pcmcia storage upto 2TB, it's not much expensive than the enabler on its own.
Reply 4 of 14, by ppgrainbow
lolo799 wrote on 2023-12-29, 09:23:
The version of SystemSoft CardSoft 16/CardWizerd that I have installed on the Tecra 500CDT is version 4.11.02C which for some reason doesn't properly support PCMCIA storage cards above 1 GB.
Isn't there an updated version of SystemSoft CardSoft 16/CardWizerd that will be able to recognise CF drives above 1 GB? Just wondering. If you have found one, let me know. 😀
Reply 5 of 14, by ppgrainbow
Bondi, I have tried to install the drivers for the Phoenix Card Manager 4.02 and Systemsoft Cardsoft 5.30.10 for the Toshiba Tecra 500CDT laptop's PCMCIA card which uses the Toshiba ToPIC95 chipset.
I haven't had much luck in getting the Cardsoft 5.30.10 drivers to work and when I tried to do so, I get this screenshot below:
755.65 KiB
When I tried to select the make of the PCMCIA adapter inside the machine, I get two "Do Not Install Socket Services" selections! 🙁
I did manage to get the wired network card regonised, but not the SanDisk Ultra 2 GB CF card.
What should I do, should I load the Toshiba ToPIC95 chipset driver in the CONFIG.SYS file? Just curious to ask.
Reply 6 of 14, by Bondi
ppgrainbow wrote on 2024-01-04, 03:14:
Bondi, I have tried to install the drivers for the Phoenix Card Manager 4.02 and Systemsoft Cardsoft 5.30.10 for the Toshiba Tec […]
From what I see Cardsoft did not reconnize the chip, as the Socket Services driver is responsible for PCIC support and setup installs relevant driver depending on the chip model.
You can check if there is a driver file in Cardsoft folder that is named somehow after Toshiba chip. SS driver files look like ss?????.exe/sys. If no you can try those with 365 number in the file name, which are Intel compatible. But I wouldn't put much hope it will work.
And did you thry Phoenix drivers? Also wonder what is special about 4.02 version vs 4.01?
Reply 8 of 14, by ppgrainbow
lolo799 wrote on 2024-01-04, 15:56:
You can put a device statement with the SSCBTO95.SYS in config.sys and check what it says during boot.
When I tried to load the SSCBTO95.SYS driver into line 18 of the CONFIG.SYS file, I get this error message:
Device Extension Services unavailable.
Upon starting MS-DOS, I had to hit the F8 key to go through all of the drivers that are loaded in the CONFIG.SYS file.
Isn't there another device driver that works with the Toshiba ToPIC95 PCMCIA/CardBus chipset that works with the Tecra 500CDT laptop?
Reply 9 of 14, by ppgrainbow
Bondi wrote on 2024-01-04, 12:30:
From what I see Cardsoft did not reconnize the chip, as the Socket Services driver is responsible for PCIC support and setup ins […]
I try the Phoenix Card Manager 4.02 driver and it didn't work. PCM 4.02, released on January 9,1997 supported removable media larger than 504 MB as I have the SanDisk Ultra 2 GB CF card inserted in the PCMCIA slot.
Reply 11 of 14, by ppgrainbow
lolo799 wrote on 2024-01-06, 13:11:
In the bios, is it set as 16bit pcmcia or cardbus?
In the CMOS setup, the PC Card Controller Mode is set to PCIC (PCMCIA) compatible. At one point, I had changed it to CardBus/16-bit (16-bit multi-function card, CardBus and ZV port card) and it would neither recognise the Compact Flash card nor my Xircom CreditCard Ethernet IIps card.
By the way, I have tried the patched CBATA driver, but that only works if I get the PC Card Controller Mode to CardBus/16-bit. Does anyone have a patched version of the UNATA driver (without the 14-day evaluation period)?
I tried to patch the UNATA driver myself, but got a error message CRC32 error: version mismatch, or file is already patched! I can't afford to pay for a driver when I already spent over $450 during the Christmas holidays. 🙁
Reply 12 of 14, by Bondi
ppgrainbow wrote on 2024-01-04, 20:26:
Could you upload the 4.02 version of Phoenix drivers, please?
PS Sent you a PM re unata enabler.
Reply 13 of 14, by lolo799
ppgrainbow wrote on 2024-01-07, 07:32:
In the CMOS setup, the PC Card Controller Mode is set to PCIC (PCMCIA) compatible. At one point, I had changed it to CardBus/16- […]
It needs to be set to Cardbus for the SSCBTO95.SYS driver.
Reply 14 of 14, by ppgrainbow
Bondi, lolo799. I think that I somehow solved my problem.
I had to load the CE2PD driver before I loaded the patched UNATA driver in the AUTOEXEC.BAT file. The UNATA driver managed to recongise the 2 GB compact flash card without problem! Now, if I can get the UNATA driver to play nice with the Xircom CreditCard Ethernet IIps card, then I probably won't have too much of a issue having to run software off of the 2 GB CF card. 😀
I'll update this reply with screenshots for the clarification.
