First post, by VenomSpark
hi all 😀
Sorry if is wrong section, my apologies in case.
Will be fast: i was playing the original (GoldSrc edition, from the CD) Half-Life 1 on my W98 PC with a SiS Mirage Real256E integrated GPU.
Game runs fast and clean, only problem is both in OpenGL and Direct3D rendering, there is no texture filter and looks really awful.
Don't really care much about antialiasing, but it looks like the texture filter is even below bilinear and looks very bad, like after 30cm on the ground is all blurry. There is any way to enable it, like any console or command to put on the .exe file?
Sadly, the driver panel of this iGPU is one of the worst evere seen under W98: you can basically change only the colors and brightness of the screen. Literally zero graphic options, no vsync, no AA, no AF, nothing.
Thanks for any help!
ASRock 939S56-M
AMD Athlon 64 4000+ 2.40Ghz San Diego\Toledo (Single Core) 1000Mhz HT FSB
1024MB DDR400 Dual Channel (512x2)
ASUS Nvidia GeForce 6800 GT PCIex 256MB GDDR3
ESS Allegro-1 (ES1989S) PCI
Win98SE+XPSP3+VistaUltimate
HP 56 15" CRT
Reply 1 of 4, by Sombrero
Create a file called autoexec.cfg in your Half-Life installation folder and add this to it:
gl_ansio 16
Reply 2 of 4, by leileilol
SIS has some strange cluster filtering for multitextured surfaces that kicks in at certain resolutions and there's nothing you can really do about it (than maybe changing the res or hex'ing out a multitexture extension). It's very obvious on lightmaps.
Sombrero wrote on 2024-02-23, 05:09:
gl_ansio 16
there is no gl_aniso on retail half-life
long live PCem
Debian's fucked
Reply 4 of 4, by Sombrero
leileilol wrote on 2024-02-23, 05:20:
Welp. I had that on my notes I made years ago, looks like I either read about commands for the Steam release without realizing or just happened on someone who also wasn't aware it doesn't work on retail.
