First post, by kotel
Hi
A while ago i got this Aopen CRW5232/ARR CD writer. After pluging it in, the LED lights up for a quarter of a second, then the drive dies. Drive isn't detected at all. Any ideas what might be the cause of this?
"Sent on a mission, to protect the last treasures. Through struggle and strife we can see the light. Even if our mission is partially complete, Our efforts are not in vain.
Let that be our legacy."
-Stronghold 5-5
Reply 1 of 7, by dominusprog
You have to inspect the board. Post a photo if you can.
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 7, by kotel
dominusprog wrote on 2024-03-04, 20:37:
Didn't spot any obviously broken compotents. After a while, The RICOH RL3E804 starts slowly heating up.
-Stronghold 5-5
Reply 3 of 7, by dominusprog
First, check the fuse (first pic, top left). Then you'll have to check the mosfets.
Reply 4 of 7, by kotel
dominusprog wrote on 2024-03-05, 15:58:
You mean L1? It has 1 ohm. Mosfet Q1 has 3.3v on base and Q2 1.89v on base too. No shorts to ground. Also, i was wrong about that RICOH chip. Its getting really warm after a couple of seconds. Any ideas?
-Stronghold 5-5
Reply 5 of 7, by dominusprog
It's probably gone bad. These chips aren't supposed to get hot, except for the chip on the left (pic 3).
Reply 6 of 7, by kotel
dominusprog wrote on 2024-03-05, 19:39:
Is there anything else i can test? Also, are there any similar replacements for that RICOH chip? I can't find anyone selling that exact chip.
-Stronghold 5-5
Reply 7 of 7, by nhattu1986
kotel wrote on 2024-03-06, 19:22:
I don't think there are anything you can check, this chip basically the heart of the drive, if it got shorted (get so hot when apply power) then you had better find another drive and moving on
you can keep the laser/spindle and use them as replacement part.
