First post, by van101
Hey everyone,
I'm struggling with a scaling problem on my old PC running Windows XP with an Nvidia 9600 GT graphics card. I've tried different driver versions like 175.19, 275.33, and 327.23, but I can't seem to find the scaling option for my LCD monitor.
I'm using a VGA connection through a DVI adapter, and no matter what driver I install, the scaling option just won't show up.
Any ideas on how to get scaling working on Windows XP with this graphics card?
Reply 1 of 7, by bobsmith
Are you referring to the DPI scale? That would be in the Advanced dialog in the Settings tab of the Display properties.
Reply 2 of 7, by van101
bobsmith wrote on 2024-03-21, 13:21:
No, Aspect Ratio adjustment, no matter the version I use no option shows up in the control panel
Reply 3 of 7, by Joseph_Joestar
van101 wrote on 2024-03-23, 04:08:
I don't think these scaling options are available over a VGA connection. The only time I've seen the scaling subscreen appear in Nvidia drivers newer than 8x.xx was when using a DVI to DVI connection with an old, mid-2000s LCD monitor which wasn't HDMI compliant
file.php?id=126877
In some cases, it may be possible to apply scaling when using with a DVI to HDMI adapter by entering custom commands, as described here. I found that method to be somewhat unreliable though, as the settings do not always persist after a reboot and/or after a resolution change.
Reply 4 of 7, by van101
Well crap, the monitor I have is only vga, are there any alternative to this? using an external program for example
Reply 5 of 7, by Joseph_Joestar
van101 wrote on 2024-03-23, 04:35:
Not sure.
The crappiness of Nvidia drivers is what ultimately led me to get a monitor which can handle this in its own firmware. I found that most widescreen LCD monitors allow for aspect ratio adjustments over VGA, but not many can do it when using a digital connection like HDMI or Display Port.
Reply 6 of 7, by van101
Unfortunately, this crappy lg monitor doesn't support this, I have a crt monitor on the way, but it's going to take a while to arrival, I was hoping to at least fix this in the meanwhile.
Reply 7 of 7, by van101
Well, I'm gonna mess around with dxwind and see what I can do
