First post, by pshipkov
Got this motherboard a while ago.
It does not recognize any memory.
The counter stops at 64Kb.
Tried with a lot of different and trusted modules - no.
Seller assured me the board came from a working system.
I believe him - very good experience with him, etc.
He runs a store on EBay and i can tell he cares about his customers.
Anyhow.
So, i am a bit unsure how to proceed from here on and looking for hints.
Visually the PCB is in very good condition.
No scratches or damage to the rails.
In addition to the modules - tried different CPUs, VGAs - long shots, but still.
retro bits and bytes | DOS media library
Reply 2 of 11, by rasz_pl
https://theretroweb.com/motherboards/s/minta- … ies-co-pcb-201s
over 30 years old, big board, looks 2 layer? something could have cracked in transit like solder under simm sockets, plcc sockets arent the most reliable either
https://github.com/raszpl/440BX Reference Design adapted to Kicad
Reply 3 of 11, by Horun
What type ram are you using ? Can you post a picture of them ?
The board accepts 256k and 1Mb Parity 30 pin. You need at minimum 2, start in bank 0. Make sure you set the dip switches proper.
They should be 9chip type (3 chip type may work but doubtful) and at least 80nS or faster..
added: never seen jumpers for "low " and "high" parity before. Maybe has to do with those...I cannot tell from the picture if they are disabled..
Reply 4 of 11, by pshipkov
@rasz_pl
Thanks for the link.
Hard to say if cold joint or something else happened to it on the way here.
Will run it with the hotgun tomorrow. Maybe even bake it. Will see.
@Horun
What tried so far:
2x256Kb
4x256Kb
2x1Mb
4x1Mb
Tested the switches combos both ways:
- ON is "C" for closed
- ON is "O" for open
The 256Kb SIMM modules are 5 chips. Or were they 6 ? Cannot remember right now. Away from them.
Tried 1Mb modules with 3 and 9 chips.
No difference so far.
Reply 5 of 11, by BitWrangler
Looks like you've got buffers on your memory bus, they can be trouble. Look socketed so maybe swap them over see if the error changes.
Edit: Oh wait, someone maybe replaced an F with an HC there, maybe it isn't quick enough.
EditII: if error goes away when you put 60ns in it, I bet that's it, can't take the extra few ns of the latency through the HC with lower speed RAM.
Reply 7 of 11, by rasz_pl
before replacing anything try deoxit all socketed chips
BitWrangler wrote on 2024-04-01, 03:42:
exact same combination on theretroweb picture, looks like factory setup
Reply 8 of 11, by rmay635703
Could try a slow oscillator and underclock the board, if something is flakey that can get it stable enough to run a post card
Reply 9 of 11, by BitWrangler
Wait, it's not being a dumbass because it's CMOS settings are invalid is it? There was one machine I came across way back would only count first 64k, would give checksum failed on the same line, then if I waited another minute or two, got POST screen, loaded defaults in setup and it was all good. Just saying some boards aren't real clear about what they are failing sometimes and some don't count full RAM until setup run, and some are jerks about both.
edit: come to think of it, was a fairly similar looking AMI BIOS 286, same size and color PCB, but had a bank for discrete RAM chips and 4 SIPP on, also learned me about the color cycle option on AMI BIOS because it came up in that eyeball melting pink and green as default.
Reply 10 of 11, by pshipkov
Ok, so the order of ops:
1. Try what BitWrangler said. I admit, i didn't wait long enough. But in some configs i do get parity error.
2. Try replace the two socketed chips next to SIMM slots. If i find counterparts - easy, so why not do it.
3. Downclock further. Also easy - one crystal oscillator socket insertion.
4. Not sure what deoxit socket chips means. Have to look it up.
