Error in AbandonLoader
First post, by Guest
I'm using Abandon Loader 0.8b and trying to run the dos game Master of Magic. I'm trying to use VDMSound, but every time I get this error:
C:\PROGRA~\VDMSound\VDMSRun.pif
%VDMSPATH%\AUTOEXEC.VDMS. The system file is not suitable for running MS-DOS and Microsoft Windows applications. Choose 'Close to terminate the application'
Could somebody please tell me what's wrong????
Reply 5 of 28, by Reckless
I guess you didn't have a PC when it was just DOS? The game is probably referring to a lack of conventional RAM (0-640K). Search the forum/web for details on this and how to configure your DOS environment to have as much as possible. VDMSound uses some of this RAM so it *might* be that the game will never fit though I don't have it and I don't feel like doing your legwork 🙄
Reply 7 of 28, by Guest
How do I do that? You're talking to someone who has no knowledge of Windows command lines (except for things like SET PATH and CD and DIR). I've always used Unix Putty for my command line work on my website scripts. Could someone please give me detailed instructions on fixing this memory error? MoM is my favorite game, and I haven't been able to play it since upgrading to XP.
Reply 8 of 28, by vladr
You open up Notepad, you paste in Snover's line (without the double-quotes), and save as "showmem.bat" (with the quotes around the file-name). Then you "Run with VDMS" this file, and see/attach the result file.
Cheers,
V.
Reply 12 of 28, by Reckless
eL_PuSHeR wrote:
I wasn't aware you could redirect things to an IP address, Everyday you learn something new. THANKS SNOVER!!! 😁
He's *not* 😀 He's just creating a unique filename (probably the IP of the person who posted the message).
Reply 14 of 28, by Guest
Here's what the text file says:
Conventional Memory :
Name Size in Decimal Size in Hex
MSDOS 11968 ( 11.7K) 2EC0
KBD 3296 ( 3.2K) CE0
HIMEM 1248 ( 1.2K) 4E0
COMMAND 3776 ( 3.7K) EC0
FREE 112 ( 0.1K) 70
FREE 634784 (619.9K) 9AFA0
Total FREE : 634896 (620.0K)
Upper Memory :
SYSTEM 212976 (208.0K) 33FF0
MSCDEXNT 464 ( 0.5K) 1D0
REDIR 2672 ( 2.6K) A70
DOSX 34848 ( 34.0K) 8820
MOUSE 12528 ( 12.2K) 30F0
FREE 960 ( 0.9K) 3C0
FREE 26480 ( 25.9K) 6770
FREE 36576 ( 35.7K) 8EE0
Total FREE : 64016 ( 62.5K)
Total bytes available to programs (Conventional+Upper) : 698912 (682.5K)
Largest executable program size : 633808 (619.0K)
Largest available upper memory block : 36576 ( 35.7K)
1048576 bytes total contiguous extended memory
0 bytes available contiguous extended memory
941056 bytes available XMS memory
MS-DOS resident in High Memory Area
Reply 19 of 28, by Qbix
Rank DOSBox Author
DOSBox Author
hmmm not sure. Mom is tricky I remember it doing sometimes weird things when I fixed some bugs withit in dosbox.
Remember that master of magic itself is quite bugged as well.
Water flows down the stream
