First post, by czero
Hello! Not so long ago I've become a happy owner of Creative 3D Blaster Voodoo 2 (12MB). I'd like to know if I could use Glidos with native 3Dfx Glide render. I've tried to replace glide2x.dll from Glidos package with 3Dfx native library (provided by driver), but the trick didn't work out 🙁 (Error). I use latest FastVoodoo XP driver and Win XP. Is there any hope to make it work?
Reply 1 of 8, by Glidos
That's the right thing to try. What was the error?
In any case, you wont get TRX packs working that way: the glide wrappers supplied with Glidos have support for a Glidos-specific Glide extention.
Reply 2 of 8, by czero
GLIDOS MFC Application Error
AppName: glidos.exe AppVer: 1.35.0.0 ModName: glide3x.dll
ModVer: 3.3.0.667 Offset: 0000b834
Then message box with "Read failure" text shows up.
Debug information included to this reply.
Is it possible to disbale glide-wrapper specific extensions in Glidos? Because Glidos is the only application, which works with DOS Glide games in NT virtual DOS machine...
    e6c5_appcompat.rar
    1.97 KiB
    484 downloads
    Debug Info
Reply 3 of 8, by DosFreak
Not true. Dgvoodoo works with DOS glide games in NT. You just will not be able to use the Hiresolution Texture Packs for Tomb Raider if you use DgVoodoo.
Make your games work offline
Reply 5 of 8, by Glidos
The extensions are used only for the TRX hires packs, so Glidos will stick within the original Glide API provided you don't install the packs.
Reply 8 of 8, by Glidos
Oh ok. I don't know why that doesn't work. There have been other people tried similar and succeeded.
Trying an earlier version of Glidos might help - before I changed over to providing the choice between OpenGlide and psVoodoo.
