First post, by BloodyCactus
So I thought its time to release some of my old stuff, I wrapped it in an installer.
Inside my installer;
https://bloodycactus.com/files/bcactus_install.zip
so the installer doesnt install the zips (I grabbed my 00index.txt off my local ftp), it installs the utils/apps etc.
(This version of the installer is output to stick on 360kb disks if you want to do a physical media install, or just unzip it into a directory and run install.exe)
Lots of this is really old, and I still use a lot of it today on my machines (my uansi driver, umb driver on my tandy, my packer, sickview etc).
Some of this I recompiled with newer open watcom but made no code changes, a couple of things I tweaked but didnt change
anything else (versions/dates etc its not worth tracking).
Some things (like amber) I had like 50 copies laying around in various states, so I dont know if the one in here is the last/most recent
or not but it seems ok. Some things are still missing (my spreadsheet uCalc and programmers text editor and some other stuff).
Some things in here are designed for 8088/XT, a lot of 386+ etc.
28line.zip       Sets screen into 28 lines mode
2pack.zip 2Pack is a small txt packer for development
50line.zip Sets screen into 50 line mode
amber.zip CPU emulator extractor (like unp).
av.zip ArchiveViewer v0.3c
bfhook.zip bios font hook. Made for emags that use unreadable dos fonts.
biowar.zip E-Mag: Biowar
bitops.zip Simple bitops tool for modifying bytes in a file
com2exe.zip Convert a COM file into an EXE file.
d.zip D - Dos directory lister tool
dc.zip disk clean. basically a 'fast format', clears the FAT entries on disks.
dekript.zip Unscrambles a 'kript'ed file.
dkd32.zip DeKompress DOS32 v0.4 by Dark Fiber, Entropic Coders '96.
dmg103d.zip Disk Magazine Generator v1.03d
dram_chk.zip Tests the DRAM banks on a VIA VT82C496G chipset.
e820.zip This is a fake E820 bios extended memory map driver
e820lst.zip Dumps the E820 memory tables if your BIOS supports them.
fedit.zip HEX File Editor (Does not play nice under dosbox, works fine on real machine)
iff_copy.zip Copys a named chunk from an IFF file
iff_list.zip Lists all the named chunks in an IFF file
iff_wad.zip Creats a simple 'WAD' file as an IFF, with ... files!
ilfs202b.zip ILFS v2.02b - Internal Library File System
info-le.zip dumps info on LE executables
infod32.zip Dumps info on DOS32 executables
ipcrypt.zip Simple COM encryptor
kript.zip KRIPT com scambler
libfile1.zip ILFS v1 tool
libfile2.zip ILFS v2 tool
mcbexp.zip Memory Control Block tool
mempak.zip Packs DOS memory into contiguous blocks. works with UMB as well.
mm401.zip Dumps revision + irq of Miniman MPU 401 cards.
now.zip Now - Prints current date/time with some parameters
once.zip Use in autoexec.bat to run things only once a day when booted.
oni.zip ONI Encryption/Hashing tool
polyenc.zip EXE encryption program
post_msg.zip post_msg stamps a message to the end of an exe file as code.
rdf2d32.zip RDF2D32 converts an RDF object into a DOS32 object
relopt.zip Optimise and sort relications in an EXE
relpack.zip Pack relocations so EXE has none.
rembss.zip RemBSS - remove bss data from end of exe
sauce.zip SAUCE - Add/Edit/Remove SAUCE from a file.
sbdsp.zip Displays DSP info on a SoundBlaster.
scheck.zip Adds a self-check routine to COM file to check for tampering.
scinfo.zip Prints sound card environment info out so its easily usable
si103.zip Simple Installer v1.03
sickview.zip SiCKVieW ANSI Viewer
tandy1k.zip Bunch of utils for Tandy 1000, 1000SX for ram
tandyram.zip Tandy 1000 RAM Adjuster v0.1 - Bloody Cactus.
todo.zip ToDo cli tool
txt2exe.zip Text2Exec v1.2 - Dark Fiber [NuKE]
uansi.zip uANSI micro ansi driver
umb.zip UMB driver for XT machines
unvac.zip Decompresses Vacuum 0.x programs
uxp-01.zip E-Mag: Unexlplained Expose 01
uxp-02.zip E-Mag: Unexlplained Expose 02
vac2.zip Vacuum/2 SYS/COM/EXE/DOS32 compressor
vacuum.zip Crappy COM compressor, Vacuum 0.02a
Reply 1 of 6, by gerry
looks like lots of interesting utilities! nice to release them 😀
Reply 2 of 6, by BloodyCactus
thanks. Its amazing the things that accumulate heh.
Reply 3 of 6, by Jo22
gerry wrote on 2021-07-13, 08:57:
+1
Totally agree. 😎 👍
Reply 5 of 6, by zyzzle
Thanks very much for releasing these. There is some real gold, and it might have been lost for all time if you had not shared it with us. Truly appreciated.
Reply 6 of 6, by BloodyCactus
zyzzle wrote on 2021-08-02, 00:36:
thanks. most are just little utilities and stuff, so if you find some cool stuff or stuff you like, thats cool with me 😀
