First post, by BloodyCactus
- Oldbie
So I thought its time to release some of my old stuff, I wrapped it in an installer.
Inside my installer;
https://bloodycactus.com/files/bcactus_install.zip
so the installer doesnt install the zips (I grabbed my 00index.txt off my local ftp), it installs the utils/apps etc.
(This version of the installer is output to stick on 360kb disks if you want to do a physical media install, or just unzip it into a directory and run install.exe)
Lots of this is really old, and I still use a lot of it today on my machines (my uansi driver, umb driver on my tandy, my packer, sickview etc).
Some of this I recompiled with newer open watcom but made no code changes, a couple of things I tweaked but didnt change
anything else (versions/dates etc its not worth tracking).
Some things (like amber) I had like 50 copies laying around in various states, so I dont know if the one in here is the last/most recent
or not but it seems ok. Some things are still missing (my spreadsheet uCalc and programmers text editor and some other stuff).
Some things in here are designed for 8088/XT, a lot of 386+ etc.
28line.zip Sets screen into 28 lines mode2pack.zip 2Pack is a small txt packer for development50line.zip Sets screen into 50 line modeamber.zip CPU emulator extractor (like unp).av.zip ArchiveViewer v0.3cbfhook.zip bios font hook. Made for emags that use unreadable dos fonts.biowar.zip E-Mag: Biowarbitops.zip Simple bitops tool for modifying bytes in a filecom2exe.zip Convert a COM file into an EXE file.d.zip D - Dos directory lister tooldc.zip disk clean. basically a 'fast format', clears the FAT entries on disks.dekript.zip Unscrambles a 'kript'ed file.dkd32.zip DeKompress DOS32 v0.4 by Dark Fiber, Entropic Coders '96.dmg103d.zip Disk Magazine Generator v1.03ddram_chk.zip Tests the DRAM banks on a VIA VT82C496G chipset.e820.zip This is a fake E820 bios extended memory map drivere820lst.zip Dumps the E820 memory tables if your BIOS supports them.fedit.zip HEX File Editor (Does not play nice under dosbox, works fine on real machine)iff_copy.zip Copys a named chunk from an IFF fileiff_list.zip Lists all the named chunks in an IFF fileiff_wad.zip Creats a simple 'WAD' file as an IFF, with ... files!ilfs202b.zip ILFS v2.02b - Internal Library File Systeminfo-le.zip dumps info on LE executablesinfod32.zip Dumps info on DOS32 executablesipcrypt.zip Simple COM encryptorkript.zip KRIPT com scamblerlibfile1.zip ILFS v1 toollibfile2.zip ILFS v2 toolmcbexp.zip Memory Control Block toolmempak.zip Packs DOS memory into contiguous blocks. works with UMB as well.mm401.zip Dumps revision + irq of Miniman MPU 401 cards.now.zip Now - Prints current date/time with some parametersonce.zip Use in autoexec.bat to run things only once a day when booted.oni.zip ONI Encryption/Hashing toolpolyenc.zip EXE encryption programpost_msg.zip post_msg stamps a message to the end of an exe file as code.rdf2d32.zip RDF2D32 converts an RDF object into a DOS32 objectrelopt.zip Optimise and sort relications in an EXErelpack.zip Pack relocations so EXE has none.rembss.zip RemBSS - remove bss data from end of exesauce.zip SAUCE - Add/Edit/Remove SAUCE from a file.sbdsp.zip Displays DSP info on a SoundBlaster.scheck.zip Adds a self-check routine to COM file to check for tampering.scinfo.zip Prints sound card environment info out so its easily usablesi103.zip Simple Installer v1.03sickview.zip SiCKVieW ANSI Viewertandy1k.zip Bunch of utils for Tandy 1000, 1000SX for ramtandyram.zip Tandy 1000 RAM Adjuster v0.1 - Bloody Cactus.todo.zip ToDo cli tooltxt2exe.zip Text2Exec v1.2 - Dark Fiber [NuKE]uansi.zip uANSI micro ansi driverumb.zip UMB driver for XT machinesunvac.zip Decompresses Vacuum 0.x programsuxp-01.zip E-Mag: Unexlplained Expose 01uxp-02.zip E-Mag: Unexlplained Expose 02vac2.zip Vacuum/2 SYS/COM/EXE/DOS32 compressorvacuum.zip Crappy COM compressor, Vacuum 0.02a
