First post, by matze79
Hi i started a new Build:
BabyAT Case
- PICMIG Backplane
- iEi SBC with Core i5 1150 4750TE 35W currently (4590 on arrival)
- 16Gb DDR3 1333Mhz
- 320Gb HDD (temporary)
it also has PCI Slots and Legacy Ports (LPT, Serial, PS/2 and so on)
I can`t use Onboard Audio from the SBC as it requires additional Breakout with ICs on it which i don`t have.
Unfortunally running Ensoniq Audio PCI did not work out, the DOS Drivers won`t load.
The Q87 Chipset does not have PCI Support so it seems PCI is bridged to PCIe.
I think there is no solution for this 😉
PSU Search was bit ehm messy.
All new PSUs have 120mm Fan and on AT Case its Upside Down so it does not cool the PSU.
I found Dell PSU (Rebranded Delta with 300W) unfortunally it has no 6 Pin PCIE Connector.
I will make a Hole in the Bottom of the Case for a Additional Fan so its not visible getting more Airflow and maybe rise Case feets a few mm up.
Currently installed Mindblows 11: (Debian 11 with KDE Plasma)
Well not so easy find a LowPower Graphics Card with some Power these Days.
Currently i have
- GeForce GT630 (loud and noisy...) 2Gb
- Quadro 4000 2Gb (too much heat for AT Case)
- R9 270X 2Gb (No 2x 6 Pin Connectors on PSU)
At least HD4600 iGPU runs Crysis
Anyone knows 80mm Fan PSU with 6 Pin PCIe Connectors ?
