Reply 60 of 193, by supercordo
First run with the Ti 500 at stock. This is on my non ultra Freeway.
Reply 61 of 193, by Sphere478
supercordo wrote on 2022-01-27, 03:49:
freakin sweet!
what memory?
using the drivers recommended in the aiming for the stars thread?
using bios settings I posted earlier?
can you look over my overclocking from earlier and let me know if you come up with a different result? it was with the non ultra
Sphere's PCB projects.
Reply 62 of 193, by supercordo
Sphere478 wrote on 2022-01-27, 07:49:
freakin sweet! what memory? […]
freakin sweet!
what memory?
Single stick of 128 at c2. Using your bios settings. Used the 7.76 drivers with the edited ini.
Reply 63 of 193, by Sphere478
supercordo wrote on 2022-01-27, 13:21:
freakin sweet!
what memory?
single sided? It occurs urs to me with the ram issues on these boards that we should be giving the chip details for future readers.
Reply 64 of 193, by supercordo
Sphere478 wrote on 2022-01-27, 20:06:
freakin sweet!
what memory?
Yes single sided. Sorry.
Reply 65 of 193, by supercordo
Put 3 sticks of my double sided Kingmax TinyBga PC-133 128 MB CL3 and got 50 more points. They are running at turbo and CL2. The agp drivers that came on the cd for this motherboard seem to be the best.
Reply 66 of 193, by Sphere478
supercordo wrote on 2022-01-27, 23:57:
have you overclocked the ti500?
try windows 95?
that's still like 1000 points shy of the record from the k6 aiming for the stars thread
which is surprising, we may need to start bios tweaking.
I also have some bga ram on the way (pc150) some 256 and some 128 but the max settings are already working with the ram I have, another reason we need some more bios options
and my own ti500 I think the record was with a ti200 (a ti500 should be faster though)
Reply 67 of 193, by supercordo
Sphere478 wrote on 2022-01-28, 01:34:
have you overclocked the ti500? try windows 95? […]
try windows 95?
I have not overclocked the Ti500 yet. Been getting my drivers figured out. My issue is i have a 400atz and from what i have been reading they dont like going over 600mhz.
Reply 68 of 193, by Sphere478
supercordo wrote on 2022-01-28, 02:29:
try windows 95?
my 550 seems to crap out around 630 or so, highest I've gotten it to post is 670
the non ultra seems to be pretty worthless above 100 fsb because the cache won't work at 112 setting if you figure out how to make it work lemme know
you could upload that driver cd to vogons driver library and link it here 😀
still no word on that bios for the ultra
my only idea is somehow getting less than 112fsb working but more than 100 by using that option in the bios. problem is it kept forcing me to set 66fsb to reset it and it kept clearing the bios settings 🤣. I never actually got it to work in a useful way. you could try.
Reply 69 of 193, by supercordo
Sphere478 wrote on 2022-01-28, 04:21:
my 550 seems to crap out around 630 or so, highest I've gotten it to post is 670 […]
try windows 95?
I put in on archive.org
https://archive.org/details/freeway-driver-cd
Reply 70 of 193, by Chkcpu
Hi Sphere478, you requested my take on the 5VGF+/Ultra board and BIOS, so here is my 2 cents. 😉
I see that they upgrade the VIA south-bridge from 586B to 686A. The 586B limited you to UDMA33, but with the VT82C686A you get UDMA66 support on the IDE channels, 2 more USB ports, and Audio.
Although the north-bridge is still the same 598MVP, you cannot use the 5VGF-H7-0330 beta BIOS on the Ultra. The ultra needs a VP3-686A-2A5LEM2QC BIOS to support the functions of this new south-bridge.
I’ve checked the 08/09/1999-VP3-686A-2A5LEM2QC-00 Ultra BIOS (FW-5VGF+/ultra-D1-0809) and it has K6-2/-III support but it doesn’t know K6-2+/-III+. It does however support HDDs up to 128GiB so luckily no 32GB or 64GB limit bugs in this BIOS.
I expect the 03/23/2000 BIOS to support the K6plus so I hope you can get it from the seller. I wouldn’t know where to find it otherwise.
Jan
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 71 of 193, by Sphere478
Chkcpu wrote on 2022-01-30, 15:42:
Hi Sphere478, you requested my take on the 5VGF+/Ultra board and BIOS, so here is my 2 cents. ;) […]
Jan
Thanks Jan! :p do I wonder, what the latest bios was that was ever made for this board was.
Any thoughts as to how we may add more control over memory and cache timings?
Hopefully anyone reading this if you know or have a newer one sign up and post it :p
Reply 72 of 193, by Sphere478
Bad news, the bios disk I had been asking him to upload was shipped with the motherboard. Last time I ordered from this guy it took a very very long time to get the board.
Good news is when I finally get it, it will contain a ultra, a ti500, and some pc150 bga ram!
Help! Trying to find bios update for freeway motherboard I’ve reached out to the community for help.
I think even this bios that is on it’s way is likely not the latest bios. So hopefully someone out there knows where they went.
Reply 73 of 193, by supercordo
Little Sneak peek. First run on the ultra board. Don't ask for details I'm not done yet.
Reply 74 of 193, by Sphere478
supercordo wrote on 2022-02-03, 01:38:
123 fsb!!! W00t!!
With cache enabled?!?😱
Hey, do me a favor, how’s halo playing on that? :p
Reply 75 of 193, by supercordo
Sphere478 wrote on 2022-02-03, 02:52:
123 fsb!!! W00t!! […]
123 fsb!!! W00t!!
Cache enabled as you can see in CPUz. The Ti 500 is also not overclocked yet.
Reply 76 of 193, by Sphere478
supercordo wrote on 2022-02-03, 02:56:
123 fsb!!! W00t!!
These are good results. But idk if it’s going to be enough to hit the record. 🙁 darn. I was hoping for more. Try win 95
Have you used the k6 tool tools to enable write combining before these runs?
I think the bios you are using now may be a little lacking in k6 + support. I still have not had much luck tracking down a newer bios, our only hope remains the board that I ordered.
Also, try only using the oldest direct x that will run 3dmark 2000
Reply 77 of 193, by supercordo
Sphere478 wrote on 2022-02-03, 04:06:
These are good results. But idk if it’s going to be enough to hit the record. :( darn. I was hoping for more. Try win 95 […]
123 fsb!!! W00t!!
I got windows to load at 133mhz with cache enabled but im having issues getting it stable. Havent used any tweaks yet.
Reply 78 of 193, by Sphere478
supercordo wrote on 2022-02-03, 05:08:
133 fsb I assume you mean.
have you upped the I/O voltage?
cut the ram timings, run memtest, and start adding them back one by one
if that doesn't stabilize it then change the cache timing option, if that doesn't work disable mainboard cache.
