Retro Rig Photo Thread
Reply 2360 of 3196, by A001
dr_st wrote on 2022-11-12, 19:50:
A001 wrote on 2022-11-12, 15:52:
PIII 866 512M 133 CL2 GF3 80GB HDD W98 SE […]
PIII 866
512M 133 CL2
GF3
80GB HDD
W98 SE
Very nice machine. Did you connect the front-panel ports somehow?
No, not yet. I don't know how that would be possible to accomplish with USB3. I'm thinking of a sleek IDE to (micro)SD adapter to move files to the computer, instead of using the built-in USB.
Reply 2361 of 3196, by dr_st
If there are at least USB2 and AC97 front audio headers on your board, then adapters from USB3 / HD Audio front panel cables can be used.
Reply 2362 of 3196, by A001
The best I can do is 1.1.
Reply 2363 of 3196, by Obijuan1983
My Retro Rig Corner!
Reply 2364 of 3196, by dr_st
Nice! 3 keyboards, 3 different layouts. The one on the top left is the best one; too bad it's non-standard so almost impossible to find.
Reply 2365 of 3196, by Nexxen
Obijuan1983 wrote on 2022-11-19, 14:23:
My Retro Rig Corner! […]
- manga style shiny eyes -
Love it 😀
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 2366 of 3196, by Obijuan1983
dr_st wrote on 2022-11-19, 18:27:
What do you mean with "non-standard"? 😀
Reply 2367 of 3196, by dr_st
Obijuan1983 wrote on 2022-11-19, 23:42:
That it is not one of the standardized layouts listed, e.g., here. Hence, very few manufacturers produce keyboards with such layouts - mostly obscure brands, with not very high quality.
Which is unfortunate, because it's really the best layout - big Enter, big Backspace - and for the backslash it sacrifices merely a portion of the right Shift which is longer than the left and not used as frequently.
Reply 2368 of 3196, by Demo85
I've stashed nearly all the beige and quirky hardware away and this is the machine that gets most use, as it simply works. […]
PIII 866
512M 133 CL2
GF3
80GB HDD
W98 SE
I'm gonna copy your case choice for my X58 WinXP/Vista/7 build.
Reply 2370 of 3196, by A001
Demo85 wrote on 2022-11-21, 02:04:
PIII 866
512M 133 CL2
GF3
80GB HDD
W98 SE
It's definitely not worth the 50eur asking price today but otherwise quite an adequate case. Previous 20-30eur yes.
Reply 2371 of 3196, by Yawnald
I love seeing high quality Noctua fans in a lot of these systems. They'll stand the test of time.
Mr. Tualatin
Reply 2372 of 3196, by Obijuan1983
IBM Netfinity 3500
Just restored this nice server 😀
2 x Pentium II 233MHz
256MB RAM
2 x 9.1GB SCSI HDD 7200rpm
S3 Virge GX2 AGP SVGA
2 x IDE Controller
FDD Controller
Ethernet
Reply 2373 of 3196, by Demo85
Here is my Win98/ME retro build, Core Duo E4600, ASRock 775i65g, GeForce4 Ti 4200 with a Zalman cooler, and of course my Diamond MX300. It's all going into a Dell XPS M166s case. Just testing fitting to see what needs to be done for wiring it up. Does anyone know if custom length IDE and Floppy cables are a thing? I'm planning to run the boot drive off a SATA SSD that I have in one of the rear caddies, thinking that will make it easy to swap OSes and what not. Was really happy with the performance when I had it all setup on the test bench.
Reply 2374 of 3196, by Private_Ops
A001 wrote on 2022-11-13, 19:15:
PIII 866
512M 133 CL2
GF3
80GB HDD
W98 SE
USB 3.0 to 2.0 internal adapter. They work fine.
Reply 2375 of 3196, by mrzmaster
Demo85 wrote on 2022-11-29, 22:19:
Love the simplicity and cleanliness of this build. I'm also in the process of slowly collecting parts for a ASRock 775i65G based build. That board is so unique and capable.
Reply 2376 of 3196, by Demo85
mrzmaster wrote on 2022-11-30, 20:29:
These late model socket 775 motherboards that support Core Duos and have SATA ports are so good for Win98. I do want to test a fast P4 vs my core duo to see if thier is a huge difference in games in Win98. Something like a P4 660 since they are cheap If only to see if these Core Duo supporting mobos with AGP are worth the premium over the ones that don't support the core duos.
Reply 2377 of 3196, by stef80
Well, Windows98/ME does not support Core2Duos ... at least not both cores 😀. 2000/XP would be better in that regard.
Reply 2378 of 3196, by mrzmaster
Demo85 wrote on 2022-11-30, 22:03:
I've selected a Pentium E5800 3.2GHz for my build. I figured the strong single core performance would probably be well suited for it.
Reply 2379 of 3196, by AvocadoLongfall
My lovely i486DX2 66mhz by Zenith Data Systems Z Select 100 XE
Originally this thing was kind of working trash and then I made it treasure. 😀
Comes installed with a sound blaster 16 isa and a front section CF card adapter in place of the old CD-ROM.
