Retro Rig Photo Thread
Reply 1220 of 3204, by Bancho
This is my "Main" system i use the most.
Intel Pentium 200mmx
Gigabyte GA-586TX3 AT motherboard
64mb PC66 SDRam
Creative 3D Blaster CT6760 16mb Voodoo Banshee PCI GFX Card
3D Sonata Yamaha OPL3/4 Sound Card
Yamaha SW60XG Wavetable card
Terratec EWS64S Sound card with 32mb Ram
Western Digital 2.1gig Hard Disk (Has that old access sound 🤣)
MSI DVD Drive
Samsung Floppy Drive
230Watt AT PSU
XFNgkXAl.jpg?2
Reply 1221 of 3204, by tabm0de
My Retro side of desktop, almost unused Compaq Presario which looked brand new in the inside and outside except brightness Bord that was broken because of pressure which I fixed, image included.
Spec:
Overdrive dx4 100, nos
8gb compact flash disk
20mb memory
2x parallel cdrom
Creative awe32 which is waiting for the DreamBlaster Synth S2 chip 😀
Old speakers
Digital keyboard, nos
Ms mouse ( laser will probably be better 😉 )
Don’t think there is anything more I can add to this setup 😀
Posted wrong thread before
naa, nothing yet...
Reply 1222 of 3204, by King_Corduroy
Nice! I'd always loved these computers. Would love to get my hands on one some day (not that I need another computer though! 🤣). Trying to get my hands on a Spectria Packard Bell but no one seems to have one. 😒
Check me out at Transcendental Airwaves on Youtube! Fast-food sucks!
Reply 1223 of 3204, by brostenen
Vallenrod wrote:
Here is my little baby. […]
CPU:
Pentium III 500MHz (Katamai).
Mobo:
Asus P3B-F 1.04 (2 ISA slots model)
Memory:
768MB (3x256 Registered ECC ram)
Sound cards:
Gravis Ultrasound rev. 3.74 (ISA non-PnP)
Sound Blaster AWE32 CT3900 with 32MB Ram (ISA non-PnP)
Aureal Vortex 2 8830A2 (PCI)
Video Card:
3dfx Voodoo 3 3000 AGP 16MB
Network card:
3com 3C905CX-TXM PCI
It's a retrofitted Dell Dimension XPS T500
I replaced the original motherboard (Dell oem version of Intel SE440BX-2).
To make it work I had to make a custom front panel adapter. Power supply also had to be replaced.
Three sound cards (cause why not? 😀)
GUS is mostly used for Sfx in dos games
Aureal Vortex 2 is for Windows games that support A3D
AWE32 is used in dos games mostly for midi music and is also installed in windows as a secondary sound device - this allows for loading custom sound fonts for GM emulation in DOS games.
Nice looking system... 😜
Is that, by the way, my old AWE32 sitting beautifully in there?
Reply 1224 of 3204, by aditya3098
My pile:
Pentium MMX 233
32 MB SDRAM
Socket 7 motherboard of unknown model (found locally)
S3 Savage4 Pro (must...get...voodoo...)
AWE32 PnP
DEC 21041-AA NIC (It has the DSUB style, thinwire and rj45 ethernet)
Floppy emulator and broken (only the front) CD drive.
CF-IDE
PSU is a Corsair VS450 (pro tip: ask your computer retailer for dead PSUs, more often than not they only have a bad cap.
Edit: Formatting
Reply 1225 of 3204, by frankmonk
Bancho wrote:
This is my "Main" system i use the most. […]
64mb PC66 SDRam
MSI DVD Drive
230Watt AT PSU
XFNgkXAl.jpg?2
I like that rig.
it looks like the Elbox Amiga 1200 Tower
Reply 1226 of 3204, by frankmonk
Almost finished my new 486 build. still need some fine tuning and of course cable management
Hercules MT Tower
Asus PCI/I 486SP3G using SCSI on Board
32MB
AMD AM5x86 133Mhz
Video: Ark Logic ARK2000 PCI 2MB
Pionner 305s Slot-in DVD RomSCSI
Sound 1: Sound Blaster 16 CT2230 with Yamaha DB50XG Daughterboard
Sound 2: Gravis Ultrasound Classic rev 3.7
2GB Seagate SCSI HDD (needs to be replaced by something quiter soon)
Reply 1227 of 3204, by bjwil1991
frankmonk wrote:
Almost finished my new 486 build. still need some fine tuning and of course cable management […]
Hercules MT Tower
32MB
AMD AM5x86 133Mhz
Wait a minute. A case that has a timer when the system gets turned on? Interesting. Must be quite handy for comparing startup times between systems.
Reply 1228 of 3204, by probnot
That is a sweet case. Full of the excessive red/green LEDs of 80s stereo equipment. I've never seen one like that before.
What is the red LED above the reset button for?
Reply 1229 of 3204, by bjwil1991
Looks like that's the power LED. The others are used as follows:
Turbo, Keyboard lock, HDD activity, and if the case is opened (might not be the case, but I digress).
Reply 1230 of 3204, by gdjacobs
Yup. Trick it out with an LED VU meter if you want to crank it to 11.
Reply 1231 of 3204, by HPI
SPEC
PC9821 XT13/C12
PENTIUM 133>>>K63-400
millennium MGA-2064w 4M
64MB
CDROM 4X
SCSI-2 HD 36G
MPU-401
PC-FXGA
WIN95
Reply 1232 of 3204, by oeuvre
ThinkPad 770
Reply 1233 of 3204, by luckybob
HPI wrote:
SPEC PC9821 XT13/C12 PENTIUM 133>>>K63-400 millennium MGA-2064w 4M 64MB CDROM 4X SCSI-2 HD 36G MPU-401 PC-FXGA WIN95 […]
SPEC
PC9821 XT13/C12
64MB
CDROM 4X
SCSI-2 HD 36G
MPU-401
PC-FXGA
WIN95
oh thats neat. id wager that roland card is practically unobtanium.
Reply 1234 of 3204, by Gered
oeuvre wrote:
ThinkPad 770
So... I've seen you post this a couple times now (definitely not a complaint!), and it's growing on me... I kind of want one now if I can find one. Haha.
486DX2-66/16MB/S3 Trio32 VLB/SBPro2/GUS
P233 MMX/64MB/Voodoo2/Matrox/YMF719/GUS CD3
Duron 800/256MB/Savage4 Pro/SBLive (IN PROGRESS)
Toshiba 430CDT
Reply 1235 of 3204, by oeuvre
Do it! They're expensive on eBay but I bought one for $50 shipped, untested. It needed to be torn apart and reassembled but now it works fine. All I did was that and buy a CMOS battery for it (CR2025).
Reply 1236 of 3204, by HPI
luckybob wrote:
SPEC
PC9821 XT13/C12
64MB
CDROM 4X
SCSI-2 HD 36G
MPU-401
PC-FXGA
WIN95
https://www.youtube.com/watch?v=uErqD09tHzU
Reply 1237 of 3204, by Rodoko
Is not that hard to obtain
The 9800/21 series (or "miko" as I call 'em since I'm a classic 9800 Touhou game lover) used a slot called C-Bus, hence the card's C shape :3
They are inserted like a Nintendo cartridge and they do have screw holes on the back instead of the common PC bracket that we the Americans use
If you go to Y! Auctions and type for example the LAPC-N you will see the card in a C-Bus format
It was like the IBM's MCA and later at the mid/late 90's NEC switched from the C-Bus to standard PCI
Also the 9821Xt is maybe from the transitional era, since it has NEC's C-Bus and PCI, you can notice it thru the dual Voodoo2's (the machine being from 1997 at least I think)
(I know all this since I love that machine together with the short lived X68000 and those two are my favorite Japanese computers and BTW, I would love to get one to play some Touhou)
And as I want to be a nice person with every Vogons member here is how a "miko" card looks like
Reply 1238 of 3204, by cuba200611
SPEC
PC9821 XT13/C12
64MB
CDROM 4X
SCSI-2 HD 36G
MPU-401
PC-FXGA
WIN95
Huh, a PC-9821Xt13/C12. I own a PC-9821Xb10/J8, but I've haven't done much yet. I still need to buy a PC-9801-86 soundboard, a replacement floppy drive (or floppy emulator; the drive the machine came with was borked), and a CF-to-IDE adaptor.
Reply 1239 of 3204, by HPI
cuba200611 wrote:
SPEC
PC9821 XT13/C12
64MB
CDROM 4X
SCSI-2 HD 36G
MPU-401
PC-FXGA
WIN95
I have done X68000 , pc98 MIDI , Fm Towns videos on my channel , those are my favorite Retro PC .
https://www.youtube.com/channel/UCxc0ohDbqm5Y … YDDMtWEQ/videos
