Reply 1260 of 2752, by Anaxagoras
- Newbie
wrote:2004 Pentium 4 retro setup / bedroom PC: […]
Specs:
CPU: Pentium 4 HT 3.0 Prescott
Mobo: GA-8SGXLFS
RAM: 2gb DDR1
GPU: Radeon 9800 PRO 128mb
HDD: 2x 40gb Seagate
OS: Windows XP Pro SP3
Monitors: 2x 17" CRT, Samsung Samtron 76E and Philips 107EI still need to get a longer S-Video and 3,5mm-RCA cables so I could connect it to that 28" Philips CRT TV. And a better CPU cooler... One that I'm currently using is from a Celeron 1.8GHz which was the original build in that case.
You have the same TV than me!!!
In my opinion, the better solution for a CRT TV is using Arcade VGA.
There are several versions. I have an old AGP version in a dedicated PC for emulators.
Your setup will be a very good emulstation!!! 😎
