First post, by MetalMilitia
Hey guys. Finally got my build up and running. Couldn't have done it without this forum. Specs listed below:
Intel (Dell) SE440BX-3 Motherboard
Intel Pentium II 400 MHz 100 MHz FSB
256 MB PC-100 RAM
nVidia GeForce2 MX400
Creative Labs AWE64 CT4520
Startech PCI USB Adapter Card
40 GB Seagate HDD
ASUS CD-RW Drive
Sony 3.5" Floppy Drive
Seasonic SS-350BS Power Supply
Antec VSK4000E Case
And, of course pictures!
Reply 1 of 17, by Keith1212
Nice build man!
Commodore PC-10
NEC 8088 Processor - 8087 Math CoPro - 640k Ram - DOS 3.3
IBM Aptiva 2144-M51
Socket 7 Pentium 166MHz MMX - 128MB Ram - Voodoo 1 - Windows 95
Win 98 Desktop
Asus P2b Mobo - Slot 1 Pentium 2 450 MMX - 400mb Ram - Voodoo 3 3000
Reply 5 of 17, by chinny22
Nice.
While I'll agree using a standard ATX connecter was stupid, and the fact you could still plug a standard ATX connector in and blow everything up was evil The cold hard fact is the motherboard being an official Intel SE440BX variant makes it one of the best slot 1 motherboards and its onboard Yamaha sound is pretty good as well.
Currant hardware makes it a great Dos/Win9x crossover PC
Reply 6 of 17, by buckeye
That case (Antec VSK4000E) is the exact same one I'm thinking about getting. Any thoughts on installing everything in it?
Reply 7 of 17, by MetalMilitia
Everything went in easily. Can't really complain about it. Cable management isn't great, but it's an older (and cheap) case so I can't really fault it. I think it's a great fit for an ATX build like this.
Reply 8 of 17, by Bj0rn83
nice build, i see you got a startech usb pci adapter i was wondering if it's better then the cheap Nec chip card from ebay?
Asus p3v133 | P533mhz | AWE64 | MT-32 | SC-55 |MU80
Reply 9 of 17, by MetalMilitia
Not sure about the NEC card, but the Startech one worked without issue. Plugged it in and Windows recognized it. I even was able to plug in the USB 2.0 front header into it so I can use them.
Reply 12 of 17, by oeuvre
svfn wrote:
Seasonic SS-350BS is an ATX psu? it is safe to use for 440BX?
Yeah, ATX and will work fine.
Reply 14 of 17, by shamino
I'm inferring a bit here, but I think you're asking about the Dell vs ATX issue for the SE440BX series of motherboards.
MetalMilitia's SE440BX-3 motherboard is a Dell version so it does have the Dell pinout.
He's using an adapter that converts the ATX pinout to the Dell pinout, that's why it's okay. You can see it in the picture.
This is only a problem with the Dell versions of these boards. These boards are also available in Intel branded versions which use standard ATX power. Don't use an adapter on an Intel branded board.
Reply 16 of 17, by sidusnare
MetalMilitia wrote on 2018-03-05, 15:58:
Shamino is correct. I'm using an adapter to safely use the ATX power supply with the Dell board.
Where did you get the adapter? I've been looking for one, I'm about to give up and make one.
