First post, by ALS
Hi everybody !
Two months ago I "found" on the mezzanine my old PC , which I used at the end of 1990's.
Motherboard - Zida 60-CREATE LX-CT
Video - Asus V3400TNT VIVO
Sound - ESS1868 with FM-tuner
HDD replaced by CF card with CF-IDE converter
Dimensions - 250x230x170 mm, for FDD or CD-ROM no more place...
For new case I was use some parts (skeleton and back panel) from industrial enclosure.
All other panels were cutted from 2 / 3mm aluminum.
New dimentions - 265x235x195 mm.
Reply 1 of 9, by ALS
Painting
In the second section of the case will be installed ATX-system.
This is not the final version, most likely, there will be a mini-ITX motherboard.
Some upgrades :
motherboard - 60-CBXICT1.00-00
sound - AWE64 Value
AT power supply replaced by ATX-PSU
Reply 2 of 9, by PcBytes
Looks really nice.
Any plans to reuse the old front panel in any way?
Reply 5 of 9, by ALS
108.15 KiB
226.36 KiB
215.52 KiB
170.86 KiB
Reply 7 of 9, by ALS
Thanks !
Side panels.
186.4 KiB
Front panel.
148.86 KiB
On the left -CPU load indicator (analog voltmeter).
In the center - the volume control knob.
On the right - universal indicator on the decatron. It can show CPU/GPU/RAM load, volume level, HDD activity and other parameters (some effects with him).
Reply 8 of 9, by ALS
Drives in AT-section :
Compact Flash 8GB (DOS/Win98) with CF-IDE adapter
DVD-RW notebook's drive with JAE adapter
drives in ATX-section :
SSD 64GB (WinXP/7)
2,5" HDD 250GB (soft/games)
238.4 KiB
273.27 KiB
