486DX2 VLB Rig
First post, by RacoonRider
It's been a long time since I last worked with hardware, and now that I've got all the things I need, I'm happy to dive into it once again!
This time it will be a 486 VLB-based system. The first packs of hardware have arrived, I'm now putting it all together to polish the whole thing later.
CPU: Intel 486DX2-50
Mobo: J-403TG 486 GREEN VLB
(BIOS string says it belongs to Lucky Star)
Cache RAM: 9x256K-15 (256Kb total)
RAM: 2x32Mb 60ns FPM with parity (hp D4892A)
Video/Controller card: ASUS GMIO-470.
Sound: Orchid SoundWave32 2Mb ROM
HDD: 635Mb WD Caviar
PSU: 200Wt AT
Generic: 3,5 drive, keyboard, speakers
Monitor: hp56 14" CRT
The CPU is rather common, nothing to add.
The mobo is a fine VLB piece of work, it has 4x30-pin memory slots and 3x72-pin slots, which, I guess, was quite common that days. The coolest thing about it is the unfamous mouse-based AMI BIOS, I always wanted to see how it works and what it looks like!
For years AMI dominated the BIOS market. Most late-model 286 boards and nearly all 386 and 486 boards used AMI's excellent Colou […]
For years AMI dominated the BIOS market. Most late-model 286 boards and nearly all 386 and 486 boards used AMI's excellent Colour BIOS. AMI's interface was simple and very easy to use.
Then, around the time that the 486DX/4 became popular, AMI switched to a new graphical, mouse-based Windows BIOS, which was supposed to be more user-friendly. It was terrible: the interface was clumsy, slow, counter-intuitive, and a real pain in the workshop where time is money and efficiency is everything.
Meanwhile, the once-popular Award BIOS had become a bit of a rarity — so much so that Award changed the traditional dark blue interface to look and feel more like the near-universal AMI Colour BIOS. No-one took much notice — until AMI introduced the idiotic new Windows BIOS, which actually looked more like an old Commodore-64. We assume that this is why Award surged ahead to dominate the BIOS market in the late 1990s. Up until just before the turn of the century, an AMI BIOS in a new system became quite a rarity.
Red Hill Hardware
Next cool part of the rig is 64MB FPM memory from a brand hp server LX. The amount is whooping for a 486! I'm not sure how much RAM is cacheable yet, but I hope my mobo can cache the whole pack.
Another curious part is ASUS combined Video+I/O card. It has a single GD5428 GPU with what seems to be 2 MB Ram and two UMC I/O controller chips.
As a sound card, I plan to use Orchid SoundWave32. It worked really well on my 386SX machine, I really like it. It sounds much better than SB32 PnP from my MMX rig and is highly compartible with most of the games I played. It's also quite rare, I suppose.
As for the HDD, I have an authentic Caviar for the system, yet I love to have a lot of space for all the stuff I keep, so I may change it to a 6 of 20 Gb Quantum HDD.
Some questions are still unsettled. The only authentic case I have is ugly, it misses buttons and has power switch on the back, which is disturbing. So I probably need a new case or an open stand. I'm also looking for a COM mouse since my last one met the Maker. I hope, she's in a retro hardware heaven 😀
I also hope to get some additional more descent sound. I'm currently looking for GUS MAX or GUS PnP, although I'm afraid GUS PnP will give a lot of trouble.
And I kind of dream of an MT-32. A dream that's not going to come true, though.
That's all for today, there'll be pictures later. Damn, I just couldn't stop writing 😵
Reply 1 of 33, by epicbrad
I wonder how this will fare on 50 Mhz with VLB? 😀
Will it work with a Dx2-66? or better?
got pics? 😀
Reply 2 of 33, by Anonymous Coward
It's a DX/2-50, so VLB should only be running at 25MHz, which is a tad slow.
Might as well upgrade or overclock to 66MHz.
Reply 4 of 33, by feipoa
If you want to cache all of that 64 MB of RAM, be sure to set your external L2 cache to write-through mode. Otherwise, you'll need to upgrade to 512 KB of cache for external write-back mode.
Reply 5 of 33, by RacoonRider
Thank you, that's just what the chipset datasheet says.
The most important part of the stuff here:
I have iSX-25, iDX2-50, AmDX2-80, AmDX4-100 for CPUs, although I'm not sure if DX4 is supported.
Reply 6 of 33, by feipoa
Nice! Time to put it all together.
By the way, that particular motherboard can only handle up to 256 KB of L2 cache.
Reply 7 of 33, by epicbrad
From memory I've got a similar board.
You'll want this
http://motherboards.mbarron.net/models/486vlb … 03tgv2.txt.html
Basically I don't think I tried such a high cpu on mine, or did I? Maybe I tried my 133. It's been a while - I've got quite a few 486's atm. This one is in a pile of "CBF" to finish as I've got one 486 in my wife's computer room being worked on 😀
It might work with the 100 just not display as amd - maybe enhanced 486 or whatever.
I found that with a number of my VLB Boards they tend not to like more than 32mb ram for some quirky reason especially when running windows on them. In dos I don't encounter many probelms. I've tried multiple ram sticks. Only on later PCI Boards I've had - it seems to go away. I honestly don't know why. Yet on one of my 1997 boards the opposite applies - It doesn't like a lot of my ram modules it's very picky.
Have you considered a CF > IDE (Ultra DMA) Solution for this PC? 😀
If you plan on doing some overclocking on VLB Boards - (Can someone explain this?) - It gets rid of quite a few problems.
I think it would be interesting to see the 80 and 100 at various settings. Although personally if you want the most compatible system I'd stick with a DX2-66 for a number of reasons.
Personally for me I don't see much point going past 16-32 mb ram on a VLB system anyway and anything more than a DX2 66 chip. If you have a much better Graphics card maybe - some good VLB cards can kick ass that's when I'd get excited 😁
What games do you want to throw at this thing (This is the part I really like to see)
Reply 8 of 33, by RacoonRider
I also have Am5x86-133ADW, But I don't expect it to work well on this board. I also think that anything higher than 66 Mhz is for later PCI boards.
And having anything close to a Pentium is not fun for me because I have a lot of Pentiums and can make anything from 75 to 233Mhz with or without MMX.
I tried DX2-50 at 66mhz, it POSTed OK, memory test OK.
3-volt AmDX2-80 at 66mhz and 3 volt won't POST. At 5 volt POSTs OK.
AmDX2-80 at 80 Mhz POSTs OK, but again, doesn't POST at 3 volt.
AmDX4-100 at 66Mhz POSTs with "Cache memory bad" message. 5 volt. 3 volt - no POST.
Am5x86-133 at 80Mhz - no POST at all
DX2-50 at 80 Mhz works fine, so I'll stick to that until I find out if I can roast my 3-volt CPUs.
wtf? It does not seem safe to use 3-volt AMDs at 5 volt, but there is no other way to get a post.
x3 multiplier is officially supported, but not supported by this exact mobo, since the pins responsible are either non-existant, or soldered, so I didn't try DX4-100 at x3 or 5x86 at x4.
Judging by memory test speeds, DX2-80 is significantly faster than DX2-50. There's a significant beep when the memory is tested, I just had to listen carefully 😀
Concenring a CF card - I'm not sure, I don't have either an adapter or a CF card, while I've got a lot of HDDs form 100 to 20 000 Mb to choose from. And 64 Mb memory is enough to have a RAM disk for whatever I need to get a fast access to. But the whole idea is curious.
And I'm not sure what games I'm going to play. Ultima 7, perhaps. And Master Of Orion - I put this on all my old rigs, it is too cool to not have it.
Reply 10 of 33, by epicbrad
Yes you are correct, I did in fact wonder why the BIOS was located in a different position on the Image of the board when doing the link.
It was the only link I could find after about 10 minutes of googling etc. Scarce or what.
I am working on a similar system albeit with a PCI bus atm. M918 Based. I've spent a good 5 hours hand picking games to archive onto a single CD so I can copy over. I've gone class DX2 - 66 Basic 2MB PCI Graphics, Classic SB16 only in a flip top case. I'm going to remove the CD drive when done and keep only 2x HDD's in there (One easy to access for transfer) and the 5.25 and 3.5 drives for looks 😀
I strongly agree with you - it seems we share something in common possibly like many other enthusiasts here. A Classic MMX System is perfect for late 90's dos games like Duke 3D / Blood etc all that kind of stuff. I also quite like them for some earlier 90's games as they work quite well (Sierra / Hugo, quite a number of classics etc - and they operate much faster minus a few for example the arm shuttlecraft grab scene in SQ5 - I Had to transfer the save game to my 386 to complete it at correct speed 🤣)
Sorry if I'm going off topic but I thought I would share my passion for the same thing by listing a few games I'm going to be playing ;
* going to try Ultima 7 (Never played)
* Lots of Adventure games (Sierra mainly)
* a lot of XT based games
* Rise of Triad
* Overkill
* Champ Kong Games
* Monopoly
* Oldschool chess apps
* Virtual Pool (Getting it working properly is the next thing)
I really REALLY want to get my hands on QEMM (Any ideas anyone?)
Do you plan on running pure dos or windows as well? 😀
What is your sound card like for OPL Based sound (Seems to be very common with a lot of 486 games I play from that era)
and what capabilities does the 2MB Rom serve you? 😀
Reply 11 of 33, by RacoonRider
The list of games is no offtopic, really 😀 Thanks for that, I'll be looking into it. By the way, instead of Googling stuff you can always try this awesome database: http://museum.ttrk.ee/th99/
I downloaded the whole thing with HTTrack and now even a large cataclysm can't prevent me from getting info on old computers 😀
I don't know a thing about QEMM, maybe it's worth digging into. In basic terms, what advantage does it give?
I'm planning to run DOS 6.22 + Volcov Commander, maybe Windows 3.1 later. Nothing like windows 95 or 98, although they would work I guess. It just does not feel right to use those things on a 486 😀
When it comes to sound cards, I'm really not an expert. From what I tried, SoundWave has good SB compartibility, supports General MIDI and MT-32 emulation, FM syntesys. On a 386SX-40 MT-32 emulation slows down the system a great deal, some games don't load, some become less playable. But if it workes there, it sound amazing. I managed to get Prince of Percia 2 to work and it literally kicked ass!
According to various sites, Orchid sw32 has ICS WaveFront syntesizer and WSS compartibility. It was made in different versions, which included a 1Mb ROM version, a 2Mb ROM version, both with or without onboard SCSI controller. ROM has compressed instrument sounds, bigger ROM equals better sound quality, I guess. It also has three 15ns RAM chips which should give a total of 64Kb cache memory.
btw, there's something wrong with my Caviar, I couldn't start the system with it as type 47 (all numbers taken from the sticker at the top). Type 45 doesn't work as well. It spinns up propperly, used to work a long time ago, but now all I get is HDD controller failure. Old Seagate ST145A works well as type 45, but I know it has a diskfull of bad sectors. Dead HDD?
Reply 13 of 33, by Anonymous Coward
After looking through your motherboard manual it appears that your motherboard has very basic support for dx4 chips. You should probably be aware that There are actually 3 different pinouts for DX4s. There is the intel pinout, the AMD pinout (AMD also made DX4 chips with intel pinouts), and the Cyrix pinout. Intel DX4 always had 16kb of cache, AMD usually had 8 but sometimes 16, and Cyrix always had 8kb. Cyrix always had 8kb writeback. Sometimes AMD/Intel chips are writeback, but sometimes write through. 3V 486DX2 chips also follow these rules.
Some motherboard BIOSes check the CPU to see what it is, and if they don't recognise it, they won't boot. The AMD 5x86 is supposed to have a workaround for this depending on if the chip is running in 3X or 4X mode.
I can't explain why your motherboard boots 3V CPUs in 5V mode, but not 3V. That's weird, and a BAD idea. If you want to run these chips I recommend an interposer, or a different motherboard. Though, it sounds like you'd be pretty happy with just a 5V DX2-66.
I recommend sticking with a 33MHz bus unless you are absolutely certain your VLB cards can handle it. Sometimes they appear to work, but then one day you get a corrupted hard drive.
Reply 14 of 33, by RacoonRider
Anonymous Coward, The exact motherboard I have can't handle DX4s, the jumpers for DX4 simply do not exist 😀 I mean, they're mentioned in the manual, but there are just empty lead dots instead of them.
OK, I'll stick with 33Mhz bus. This ASUS VLB combo seems to be a budget solution, so maybe I should not expect perfect stability at 40Mhz.
Thank you for your post 😀
Reply 15 of 33, by Anonymous Coward
40 or even 50MHz is possible with VLB, but you have to be careful...especially with your HDD controller. If you have a good quality motherboard and good quality controllers, you can do it.
Reply 16 of 33, by RacoonRider
How do I know if I do?
Reply 17 of 33, by Anonymous Coward
The best way I've found is to use google newsgroups to read articles on the subject from the mid 1990s. Certain manufacturers actually certified their stuff to work at 50MHz. For example, I am pretty sure my Hercules Dynamite Power specifically states in the manual that it supports 50MHz operation. ET4000W32P and ARK based VGA cards seem to be pretty good at 50MHz in general. I've had bad luck with S3 though.
The HDD controller is really the one to watch for though. If you get graphics corruption on your vga card, you just reset the machine and try again. However, with HDD controllers if you get drive corruption that means you need to format the drive and start over. I get around this problem by running my HDD controller on the EISA bus instead (my board is VL/EISA combo).
For motherboards, I would guess Asus boards with SiS chipset would probably work pretty well.
Reply 18 of 33, by RacoonRider
Well, BIOS string says, mobo's manufacturer is Lucky Star, so I guess I'm not that lucky 😀
Concerning ASUS combo device, there are two quarz thingies, one of which is connected to CL-GD5428, so it seems to me that graphics chip works on it's own frequency, not on VLB frequency specified by jumpers on the motherboard.
Reply 19 of 33, by Anonymous Coward
I believe those crystals are used to set display resolutions. Trust me, your card runs at the same speed as the main memory bus.
