Reply 20 of 80, by luckybob
- l33t
its just a stupid scare tactic to get you to buy their motherboard. jsut ignore it.
So that is a slot one 1ghz 100fsb coppermine SL4KL.... The rare one!!!
I should buy it then? It's new in box for a very fair price.
Retro Rig: PIII 1Ghz (SL4KL), P3B-F 1.04, Crucial 512Mb, Geforce4 TI4600, SATAII Raptor, AWE64 GOLD, STB Voodoo 2… TBC
Ok... For 40 bucks shipped for a 1ghz 100fsb NIB I ordered it. I wanted the 133 but hell this one is rare and brand new!
Sounds great but how did you uniquely identify it as SL4KL? SL4BR is also a 1000/100 slot 1. There is also the SL5QV which is s370 1000/100.
_: K6-III+ 450apz@550, P5A-B, 128Mb CL2, Voodoo 5500 AGP, MX300, AWE64 Gold 32mb, SC-55v2.0
_: Pentium III 1400 S, TUSL2-C, 512Mb CL2, Voodoo 5500 AGP, MX300
It very well could be a SL4BR. What's the difference between KL and BR? I imagine one was a retail box and the other OEM. The caution on the box calls for slot-1 mobos... So it's a 1ghz 100 fsb slot 1 Coppermine.
I did good right?
Yes of course. It's the fastest true slot 1 processor made and ideal for 440BX boards.
http://www.ebay.com/itm/OEM-Intel-Pentium-III … %3D320974218241
One left!
It's a SL4BR, which was the OEM version.... But it's new in box! What a find!
I bought the second to last one a couple hours ago. It will be going in a ASUS P2B.
Tualatin Celeron 1.4 + Powerleap PL-IP3/T, ASUS P2B, 512 MB RAM, GeForce 4 Ti 4200, Voodoo2 SLI, AWE64, 32GB IDE SSD, Dell 2001FP
Yeah the retail versions had the classic blue box. This is clearly OEM. I am assuming there would be no reason to warn against a S370 cooler fitting. It could be one of those giant passive heatsinks found on slot 1.
Also if you're on a 133mhz slot 1 board, you could grab a powerleap and a 1400S and be happy there too.
The seller is selling more: http://www.ebay.com/itm/OEM-Intel-Pentium-III … =item1e9f8d5f66 And yes it's SL4KL.
Update:
Can’t get this system to post! Here is what happens. I get 1 beep followed by 2 beeps (Bad or no display) then, constant rapid beeps (overheated cpu)
Here is what I have tried so far.
Two differnt PSU
Two different GPUs that work (Starting with no GPU results in same issues)
With 1 stick of 256mb that has made a trip in each slot which changes nothing. I tried removing the RAM (All I get is long beeps, which is to be expected)
I have tried to reseat CPU, replaced CMOS battery with new one, manually dropping the FSB to 66 to try and get it to POST. Nothing! I removed the CPU and turned it on and got nothing, which is to be expected. This only components attached are CPU, RAM and GPU and a keyboard and VGA connector.
This could be a bad CPU or Mobo.
Thanks Ebay, looks like I might have to drop serious money into a P3B-F version >=1.03
This retro PC is getting expensive.
Is $60+25 shipping worth it for a tested P3B-F v1.04?
I think that's about average price. How many ISA? I think for 2 ISA it's actually quite good.
NIB 1GHz CPU'S!!!!! I'd definitely be getting a nice matching pair if any of my duel boards could handle anything above katmai's.
If your not overclocking the Gateway Tabor motherboards are actually Intel SE440BX-3 boards with standard ATX pinout (Unlike Dell's SE440BX-3 boards)
Obviously being both OEM and Intel there isn't much you can configure but are rock solid
Yeah I agree. I bought 2 from the seller. They'll be assigned to a P2B-D Rev 1.06 D03 board that I found.
P2B-D Rev 1.06 what's the fair price for that? Duel CPUs seems wicked cool!!!!!!! I could order a second CPU and a P2B-D and build it for bragging rights.
However, If I decided to get a P3B-F does it matter if its a 1.03 or 1.04? (I know both support 100fsb coppermine)
I need some help deciding whats a smarter route from my friends on Vogons... My main plan is windows 98SE gaming.
I will let you know when it comes it. The NIB that's being sold have a Sl4KL label on them, which was the retail version no oem.... Standby, Ill do an unboxing on Vogons.
wrote:P2B-D Rev 1.06 what's the fair price for that? Duel CPUs seems wicked cool!!!!!!! I could order a second CPU and a P2B-D and build it for bragging rights.
I'm not aware of any difference other than coppermine support after 1.03. This is my one stop shop for asus 440bx info: http://homepage.hispeed.ch/rscheidegger/p2b_p … pgrade_faq.html
For ~$90 this is a 2 ISA P3B-F 1.04: http://www.ebay.com/itm/1-ISA-6-PCI-SLOTS-TES … =item2a51e42b36
My P2B-D I got from a university recycling bin along with some other motherboards (like a A7N8X deluxe which I love). They were all "open box" status. So I have the box and all of the contents. The P2B-D even has a ASUS C-P2T adapter which let's you run the dual board with one processor. I have no idea what an open box P2B-D 1.06 D03 with C-P2T, manual etc is worth. Probably at least the value of a 2 ISA P3B-F, but maybe more for the value of two cpu slots. That said I probably won't be running the setup anytime soon being happy with my k6-III+.
I keep looking at this one. http://m.ebay.com/itm/141436919069?_trkparms= … 6.c100107.m2460
Does rev 1.04 have the different clock chip like the P3V4X rev 1.03? I believe AUSU changed them and it wasnt popular. From what I've read. Do I really need or want two ISA?
On the two CPU note.
Will two 1 Ghz P3 really impress anyone? I feel the urge to buy one more of those CPUs... But the P2B-D is expensive.... A P3B-F with a 1ghz chip and a nice SLI setup sound really good too. Anyone have any experience to lend me on the debate?
wrote:Will two 1 Ghz P3 really impress anyone? I feel the urge to buy one more of those CPUs... But the P2B-D is expensive.... A P3B-F with a 1ghz chip and a nice SLI setup sound really good too. Anyone have any experience to lend me on the debate?
I rub my nipples every time someone builds a dual cpu rig. That said, you must run windows 2000 or xp, if you go dual cpu.
