Nexgen - the 486 killer - WIP
Reply 20 of 69, by feipoa
Anonymous Coward wrote:
What you quoted should be for VLB 2.0.
For VLB 1.0, I'm pretty sure it's 3 cards at 25MHz, 2 cards at 33MHz, 1 card at 40MHz and at 50MHz only one device if it's integrated onto the motherboard.
Only 2 VLB devices at 40 MHz? I can see why some boards omitted the 3rd VLB slot.
I've been using two VLB cards at 40 MHz: one graphics, one SCSI in my Asus VL/I-486SV2GX4 at 160 MHz without any issue.
Reply 21 of 69, by mpe
I started to think about which storage option is the best for this build.
The original Promise EIDE2300PLUS isn't at all a bad performer. Is an early period-correct Fast-ATA 2 implementation, it has its own BIOS and dos driver that can tweak it and drive up to PIO2 or MW-DMA speeds.
1.56 MiB
But I picked up this beautiful Adaptec AHA-2842A and given by a kind of exotic nature of this build, thought the SCSI would be a more suitable choice.
1.58 MiB
Both have a FDC controller which is great. The Adaptec lacks serial port though, but it is nothing a simple ISA card can't fix.
Performance-wise I think the Promise has potential to be a bit faster - this is due to lack of support of synchronous SCSI transfers on the SD2SCSI v5 device I am using. But I might upgrade to v6 at some point...
Which would would you chose?
Blog|NexGen 586|S4
Reply 22 of 69, by feipoa
I use the Adaptec AHA-2842A in my Am5x86-160 build (Asus VL/I-486SV2GX4). I'm not sure about the NexGen, but on VLB/ISA 486 motherboards, getting a VLB bus mastering SCSI controller card to work properly with the CPU in write-back mode can be a challenge, if not impossible. The Adaptec AHA-2842A has a jumper on its PCB to work-around this issue. It worked for my system.
For systems with weaker CPUs, like a NexGen P90 or 486, normally using SCSI over IDE reduces the CPU overhead. Can you benchmark the Promise+CF vs. the Adaptec+SCSI2SD? I have only used v6 of SCSI2SD so I cannot say anything concerning the v5 adapters. I haven't benchmarked the SCSI2SD v6 in anything faster than a 386/SXL yet, but I have booted an IBM 5x86c-100 system using SCSI2SD v6 on an Adaptec 2940U2W card and it felt as fast as the system when using a Ultra100 ATA controller.
The benchmarks on my SXL system can be found here for SCSI2SD and CFtoSCSI. SCSI2SD - Comparison of SCSI SD, CF, and HDD performance
Reply 23 of 69, by Anonymous Coward
As far as I can remember, both the chipset and the SCSI controller need the work around for writeback support. Not sure how many chipsets actually supported it, but pretty sure SiS was one of them. Do you have the chipset revision?
Reply 24 of 69, by mpe
I disabled the write-back support by opening the J5 jumper. What is it actually doing? Surely it can't control L1/L2 WB mode, because that's the matter of CPU. Perhaps it just forces non-DMA IO to ensure cache coherency?
Right now I have a problem running any sort of SCSI in my NexGen system 🙁
Adaptec AHA-2842A detects the device, but reports "Missing operating system" when trying to boot from the first drive. The OS is definitely there...
When I put in my AHA-1542CP (ISA) which boots great with this SCSI2SD and card in my other systems, it doesn't even detect devices and the SCSI BIOS times out.
I think I will need to try to move things around in BIOS.
Blog|NexGen 586|S4
Reply 25 of 69, by mpe
Got that. It is actually more sophisticated. The JP5 directly connects to B38 pin of the VL-Bus which is #WBACK to support cache coherency in WB systems.
Blog|NexGen 586|S4
Reply 26 of 69, by feipoa
Some systems, like my Acer socket 4 system also don't detect any IDE drives when I use a Promise Ultra100/133. Never figured out what the issue was, but I switched to a Promise Ultra150 SATA controller, it could detect the drives. So you may need to experiment with different controllers. On a similar note, I have an Adaptec Ultra100 RAID controller that doesn't detect my Maxtor drives, but works just find detecting 4 Samsung drives. So it could also be that your controller doesn't agree with your hard drives.
Reply 27 of 69, by mpe
Got the AHA-2842A working in NexGen.
The "Missing operating system" error was due to the fact that my boot disk is 2GB and apparently the AHA-2842A with existing BIOS can't boot from it.
My AHA-1542CP despite being just ISA has newer BIOS that can handle it just fine.
Resizing the boot disk device to 512MB worked just fine. Once booted to DOS the 2GB volume can be accessed (without any driver), so it is just a matter of BIOS boot support.
As for speed, it is noticeably slower than the Fast ATA-2 Promise controller. Only about 1200kB/s reported by Checkit. The promise is about 3-4x faster. I will have to experiment with cards/settings.
Blog|NexGen 586|S4
Reply 28 of 69, by feipoa
Could be related to how the Extended BIOS Translation is handling drives larger than 1 GB on the different SCSI cards. I've run into this between the AHA-2842A, AHA-1542CP, 2940U2W, and another non-Adaptec VLB SCSI controller (the name escapes me at the moment).
EDIT: Thinking some more about this, I think I could not move a large SCSI drive (e.g. 8 GB) between the 2940U2W and the 2842A. Similarly, I could not move the hard drive from the 2842A to a DTC 3274VL VESA Busmaster SCSI host adapter as they use different translation schemes for either above 512 MB or above 1 GB. Do move the drive around from one to the other would require running FDISK and setting up the HDD again, basically, starting over. For drive of 512 MB or less, you are usually safe to transition the HDD between various controllers.
Reply 29 of 69, by mpe
The system got the SCSI upgrade. In terms of performance it is a downgrade mainly due to slowish SCSI2SD 5 device.
1.25 MiB
I have two ISA slots left 😀. One will be taken by a network card. Still deciding on the model. I am actually thinking building a retro Token-ring or 100VG-AnyLan retro home network.
Also need to sort out cabling mess. I like the idea of placing ribbon cables under the board so that the interior of computer is tidy looking.
Blog|NexGen 586|S4
Reply 30 of 69, by Primergy
mpe wrote:
I don't blame anyone using spinning HDDs in their retro builds. But CF cards are way more practical in many ways. The best thing is that with an angle pin connector I can install it directly on the controller without wiring any ugly ribbon cables around
Here you go:
https://en.wikipedia.org/wiki/Microdrive
Hearing those spin up is the cutest thing.
Reply 31 of 69, by Tiido
I run a Mach32 and that same Promise IO card at 50MHz VLB with no wait states on OPTi 82C895 based motherboard, it runs pretty nicely but I need 10ns cache to maximise the performance on CPU end.
Reply 32 of 69, by mpe
I was experimenting with different storage options:
CF2IDE + Promise EIDE2300PLUS (in turbo mode) - 5998 kB/s
SCSI2SD v5 + AHA-2840VL - 1193 kB/s
SCSI2SD v6 + AHA-2840VL - 7739 kB/s
The SCSI2SD v6 really makes a difference. I think non-wide/ultra SCSI-2 (or anything attachable to VLB) can't be much faster than this.
Blog|NexGen 586|S4
Reply 33 of 69, by derSammler
Primergy wrote:
Here you go:
Not a good idea. Microdrives were made to be used for a maximum of 4 hours a day. They were for digital cameras mainly, not for computers. Even when being used 4h/day, they have a very short life-time.
Reply 34 of 69, by feipoa
Aside from the benchmark, does the SCSI2SD v6 'feel' faster than the v5? Does it feel faster than the Promise IDE?
Reply 35 of 69, by mpe
I can somewhat notice the difference between v5 and v6. Especially when copying files, starting Windows, etc. Progress bars when installing software run faster, etc.
The Promise vs SCSIv6 difference is IMHO not noticeable outside of benchmarks. Both are 10x faster than a period correct spinning HDD. Both in transfer speed as well as "seek" time
I plan to test also different SD and CF cards. But I believe they won't make much difference.
Blog|NexGen 586|S4
Reply 37 of 69, by mpe
Might do that with more benchmarks.
I also tried ISA Adaptec AHA-1542CP to see how the benefit of SCSI on VL-Bus
The ISA with SCSI v6 can do 1636 kB/s at nominal ISA speeds (8.16 MHz, DMA clock at 1/2 speed). ISA overclocking (14 MHz, DMA at full speed) can push this to 1909 kB/s. Not bad, but much less than VL-Bus controllers.
Also found a slightly faster SD card (Lexar 1000x) which improves the maximum SCSI2SD v6 on AHA-2842A score to 7991 kB/s. Most likely that's the SCSI-2 bus or SCSI2SD v6 ceiling.
Blog|NexGen 586|S4
Reply 38 of 69, by feipoa
Interesting. Are you able to benchmark the scsi2sd v5 on the 1542cp? It would be beneficial to know if the v6 offers any improvement over v5 on the isa bus.
Reply 39 of 69, by mpe
The v5 has done about 1193 kB/s on AHA-2842 and 1000 kB/s on the AHA-1542CP (normal ISA speed). So the V5 is slower even on ISA.
However, that's with a different card as the v5 only takes micro-SD (and mine is average class10 rated) unlike the full-size SD (premium 95mb/s rated) on the v6. This could make some (small I hope) difference.
I will try to get one of these micro-SD to SD adapters and use the same card to see eliminate the card performance difference.
Blog|NexGen 586|S4
