Reply 520 of 660, by NinjaWarrior
- Newbie
Eivind wrote on 2023-04-24, 17:25:NinjaWarrior wrote on 2023-04-24, 16:35:Well, I finally got time to test my Tinyllama and I am stuck at CS4237B eeprom programming. If I enter: […]
resource /f=0x120 /r=cs4237b.asm /e
I get CONTROL not found at 0x120 address
Tried also with the default address, same error.
Any clues?
Is this the 1.1 version of the TinyLlama? In that case, I’d double check your soldering. That command works if everything’s soldered correctly.
It is the latest one, you sent it to me assembled already. I just desoldered the DAC to put the adapter on top for the wavetable. Perhaps I did something wrong?
