TinyLlama (Vortex86EX SBC)
Reply 520 of 671, by NinjaWarrior
Eivind wrote on 2023-04-24, 17:25:
NinjaWarrior wrote on 2023-04-24, 16:35:
Well, I finally got time to test my Tinyllama and I am stuck at CS4237B eeprom programming. If I enter: […]
resource /f=0x120 /r=cs4237b.asm /e
I get CONTROL not found at 0x120 address
Tried also with the default address, same error.
Any clues?
Is this the 1.1 version of the TinyLlama? In that case, I’d double check your soldering. That command works if everything’s soldered correctly.
It is the latest one, you sent it to me assembled already. I just desoldered the DAC to put the adapter on top for the wavetable. Perhaps I did something wrong?
Reply 521 of 671, by RayeR
Also check pull-up resistor, I think there should be one at I2C data cca 4k7.... on I2C clock there's internal pull up in crystal chip..
Reply 522 of 671, by Eivind
NinjaWarrior wrote on 2023-04-24, 17:33:
Ah, if I sent it to you pre-assembled, the eeprom is already programmed! 🤪
TinyLlama 3
ITX-Llama motherboard
TinyLlama SBC
Reply 523 of 671, by NinjaWarrior
Eivind wrote on 2023-04-24, 17:58:
Unfortunately, UNISOUND does not find any PnP card, if I use /CL does not list any card either. Anyway, I should be able to flash again the eeprom despite it have been flashed before I suppose. I tried without the adapter+wavetable, same results.
Reply 524 of 671, by siffland
I got mine assembled and it works great. Did i miss the 3d files for the tinyllama v2 case on the github page somewhere. I just want it to look pretty and not get injured.
Reply 525 of 671, by Eivind
NinjaWarrior wrote on 2023-04-24, 18:46:
That is very weird, I've tested unisound and games with adlib, fm synth, digital audio samples and midi on every card I've sent out.
TinyLlama 3
TinyLlama SBC
Reply 526 of 671, by NinjaWarrior
Eivind wrote on 2023-04-24, 20:04:
I desoldered the DAC, but I soldered another one I had from the v1 kit just because it was new and easier to put in place (no tin to remove). I suppose the DAC of the v1 is the same of the v2. I tested the desoldered points and the soldered ones, I can't find any damage there. I will examine the board closely just to make sure no small tin fragment is the origin of the problem, but I find it strange really.
Reply 527 of 671, by Eivind
NinjaWarrior wrote on 2023-04-24, 20:10:
Can you take a screenshot of running the unisound command? Also, I assume you've set the BLASTER environment variable first?
TinyLlama 3
TinyLlama SBC
Reply 528 of 671, by NinjaWarrior
Eivind wrote on 2023-04-24, 20:14:
Yes, actually I am using the config and autoexec from the github. Oh, BTW I use a powered VGA-HDMI converter, I don't know if that may be a source of problems. I use also a 36W type-C power charger with fast-charging. I don't know if that matters.
Reply 529 of 671, by NinjaWarrior
Ok, I found the problem... and I feel REALLY stupid...
After checking all parts, the soldering, etc. All was ok. The problem was just ME:
I was using the Tinyllama v1 files (INITBIOS.ROM and unisound were different on github repos).
So, I proceed to flash the right v2 firmware. Made the USB, booted and flashed... and bricked 🙁
I checked the USB INITBIOS.ROM and the file was corrupted. The f***** pendrive just failed. Guys, something don't want me to use the Tinyllama.
So, I flashed a corrupted firmware, nice. Now the Tinyllama is bricked. Any way to unbrick it?
Reply 530 of 671, by Eivind
NinjaWarrior wrote on 2023-04-25, 01:01:
Ok, I found the problem... and I feel REALLY stupid... […]
Whoa, sorry to hear! Well, the rom chip on the Vortex86EX is just a plain old 8 MB spi flash ic. You could either desolder it, put it in a SOP-to-DIP adapter and flash it using an eeprom/flash programmer, or even program it in-place using a SOP clip. I've used the TL866II Plus to unbrick the rom chip countless times while playing with the BIOS. The TL866II Plus is readily available on AliExpress for instance. Or, try checking around locally if anyone has a programmer and can help you out?
TinyLlama 3
TinyLlama SBC
Reply 531 of 671, by Eivind
Eivind wrote on 2023-04-25, 01:25:
I should add, I'm happy to do it for you, takes me 5 minutes. But shipping is pretty steep and takes a while, better to check in your own city/country first!
TinyLlama 3
TinyLlama SBC
Reply 532 of 671, by ExplodingLemur
Oof. @NinjaWarrior are you in the US? If so I can re-flash it, I've got a TL866II programmer and an SOIC clip. USPS priority flat-rate isn't too bad, I think about $10 each way?
Reply 533 of 671, by ExplodingLemur
siffland wrote on 2023-04-24, 20:03:
+1 to this question, I've got a spool of Jessie 500 beige filament begging to be made into a case 😀
Reply 534 of 671, by Eivind
ExplodingLemur wrote on 2023-04-25, 05:22:
Yeah I've been holding off publishing this case for far too long, I just haven't been 100% satisfied - but if you guys wanna have a crack at printing it yourself it's up on github now! 👍
TinyLlama 3
TinyLlama SBC
Reply 535 of 671, by NinjaWarrior
Thank you Eivind, I will ask in a Spanish retro forum just in case someone has a programmer. If negative, I will send it to you. No problem if it takes a while to return 😀 . OR, I can buy a TL86II Plus and do it myself... is it a difficult task?
ExplodingLemur wrote on 2023-04-25, 05:20:
Thank you for your kind offer! Unfortunately, I am in Spain 🙁
Well, the good side of this history is the board and the DAC mod is ok, so at the end the problem was flashing the CPU BIOS with a corrupted ROM. Next time I will hash check the ROM before flashing (I suppose there is a FreeDOS/MSDOS utility to check file hashes).
Reply 536 of 671, by vanfanel
Looking at some recent Rasteri experiments, it seems that the PCIe VGA module has some "artificial limit" set on:
https://www.youtube.com/watch?v=MQR2LxR7VdM
Maybe a BIOS update could remove that limit somehow? Or maybe another VGA PCIe chip is needed?
Reply 537 of 671, by Eivind
vanfanel wrote on 2023-04-26, 10:22:
I don't think there's anything "artificial" about it, the Vortex86VGA chip is just slow. Me and many others in here have tried various other graphics cards, and the best ones for the TinyLlama seem to be cards based on the Silicon Motion SM750 (in a handy Mini-PCIe form factor). That, combined with a healthy overclock of the CPU gives you very playable framerates in most early-to-mid 90's games.
TinyLlama 3
TinyLlama SBC
Reply 538 of 671, by NinjaWarrior
Ok, received the programmer and reflashed the BIOS with the v2, the right one. Now crystal chip is properly detected and wavetable module works like a charm. Finally some fun for the weekend!
The attachment t48_con_clip.jpg is no longer available
Reply 539 of 671, by Eivind
NinjaWarrior wrote on 2023-04-28, 14:44:
That's awesome, congrats! 😀
TinyLlama 3
TinyLlama SBC
