First post, by Chupo_cro
I was using VirtualDubMod to reencode captured videos to the XviD+mp3 (LAME) format but without success. The first weird thing is there are only ABR modes on the LAME dropdown list:
http://img147.imageshack.us/img147/5729/dosbox01hy0.png
The second is - I am getting this error
http://img402.imageshack.us/img402/1187/dosbox02hc0.png
right after conversion starts (with every bitrate selected).
I was able to convert the video with VirtualDub but the resulting video hangs my PC.
Does anyone know what could be the problem?
Chupo
Reply 1 of 2, by leileilol
Try doing audio conversion to 44khz, 16bit, stereo, THEN choose your audio compression codec
FUCK "AI"
Reply 2 of 2, by Chupo_cro
That's it 😀 Thank you very much!!
It can be all done in a single pass.
Now I have another problem. I've made a capture of Sokoban so the sound is not very important (it's only Sokoban's footsteps). I've set video bitrate to 128 Kb/s (16 kB/s) and the lowest audio CBR bitrate I can choose is 96 Kb/s (12 kB/s) so the audio data is almost as much as video data.
Is there a way to maximally reduce audio bitrate/data inside .avi so it won't take 75% of the filesize? I've tried to force 'show all formats' and to use lower bitrates but the error is:
http://img255.imageshack.us/img255/2044/dosbox03dq6.png
Chupo
