First post, by Stomp357
I'm trying to load "Spear of Destiny" without having to dig out the manual to pass the copy protection all the time (I have the floppy disk version published by FormGen). I used "NeverLock 96" to create a crack file called "Spear_K.EXE" that must be ran before running the game. Is there a way to have D-Fend run the "Spear_K.EXE" then run the "Spear.EXE" game file without exiting DOSBox between loading the two files?
Reply 1 of 3, by MiniMax
Rank Moderator
Moderator
Sure. Create a small text-file called something like RunSpear.Bat. Insert the commands you want executed:
Spear_K.EXE
Spear.EXE
save the file, and instruct D-Fend to launch that BAT-file instead of the EXE.
Ohh - and don't use D-Fend, use D-Fend Reloaded and DOSBox 0.72.
_________________
Reply 2 of 3, by Stomp357
Thanks. I feel like an idiot. While I am "self-taught" when it comes to computers, I totally forgot about a .bat file. I started with DOS 6.0, and didn't move to Windows till late '96, and still used DOS regularly till 2000. 😊
Reply 3 of 3, by Alexander
You can also just keep the "Spear.EXE" in the "game file" field and add "Spear_K.EXE" (without qoutes but with the right path) to the autoexec.bat section (on the "Starting" page of the profile editor). The lines from the autoexec.bat section will be executed before running the main game file.
BTW: D-Fend Reloaded 0.5.0 Beta 2 will be there by next week. The code is ready, I'm just writing some online help.
