First post, by Stomp357
I'm trying to load "Spear of Destiny" without having to dig out the manual to pass the copy protection all the time (I have the floppy disk version published by FormGen). I used "NeverLock 96" to create a crack file called "Spear_K.EXE" that must be ran before running the game. Is there a way to have D-Fend run the "Spear_K.EXE" then run the "Spear.EXE" game file without exiting DOSBox between loading the two files?
