conf file path
First post, by Dude123
hi,
I use dosbox 0.73 and win xp. How can I put dosbox.conf in dosbox'es installation folder instead of Documents and settings folder to where it's written by default?
thx
Reply 1 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
copy the file dosbox-0.73.conf to there
and modify the shortcut to dosbox and add
-conf dosbox-0.73.conf (possibly adding the fullpath to it in front)
Water flows down the stream
Reply 2 of 6, by Dude123
thx, this works. But why don't you write the conf file to the installation dir of dosbox by default? This is much easier I think?
Reply 3 of 6, by DosFreak
Users can't edit the dosbox.conf in the DOSBox folder unless they know about editing permissions (not very likely) or they are logged in as administrator (which they shouldn't be).
Besides written data shouldn't be stored with the program if not necessary.
Make your games work offline
Reply 4 of 6, by ripa
You don't need the -conf switch if you name the file dosbox.conf.
Reply 5 of 6, by Dude123
If I do that, will using the "edit configuration" shortcut in the start menu also use this new conf file in the installation folder of dosbox or will it create a new one in documents and settings (the default) again?
Reply 6 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
the shortcut will be broken then
