First post, by pz
Hello,
I would like to install Dosbox 7.3. and Dosbox 7.2. at the same notebook.
With Dosbox 7.3. I would use Windows 3.11 and with Dosbox 7.2 I would use Windows 1.04.
Is that possible that I would like to use two versions of Dosbox?
Thank you for your answers.
pz
Reply 1 of 8, by bloodbat
I don't really see a point to doing that, specially since the latest is 0.74; but you could install two different versions side by side in different folders; you'd probably want to point the shortcuts to use their proper .conf files, though.
Reply 3 of 8, by Miki Maus
You can run any number of instances (and with different config files) of a single DOSBox installation. There is no need for multiple installations.
Reply 4 of 8, by SKARDAVNELNATE
Dosbox 7.3... Are you from the future?
DOSBox installs to the folder DOSBox-0.xx so having multiple versions installed side by side is no problem.
Why you want to do this isn't clear. You can have multiple DOSBox windows from the same version open side by side.
Having different installs won't separate the versions of windows you run with it. You still need to mount separate locations for each one.
Reply 5 of 8, by pz
Hello,
I have read, that is possibile to install Windows 1.04 with Dosbox 7.2.
I would like to try to install Windows 1.04. with Dosbox 7.2. Under 7.3 it isn't possibible to install Windows 1.04.
Reply 6 of 8, by leileilol
How about "7.4"?
Debian's fucked
Reply 7 of 8, by sliderider
pz wrote:
Hello,
Why would you even want to? Any Windows before 3.0 was horrible.
Reply 8 of 8, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Jfyi there is no 7.x version of dosbox. There is only 0.7x versions. And yeah what's the point of installing windows 1.x?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
