First post, by oscarsrgr8t
Hello eneryone, I'm new here, I would love to play some games fullscreen, but when I press alt, enter, the screen goes black and the monitor says out of range. Also, when I put in the fullscreen commands in the DosBox, it just says illegal command etc.
Also, when I open DosBox, 2 windows open, one is the actual dosbox and I'm not sure what the other one is.
I hope someone can help
Reply 1 of 1, by DosFreak
Open your dosbox.conf and change fullfixed=false to fullfixed=true
Set fullresolution=false to fullresolution=0x0
You'll probably have to do a bit more tweaking but that should at least get it to work.
The other window is a "console" that will tell you certain things about your DosBox configuration or give you an error if something doesn't work.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
