First post, by Nighthawk
silly little problem but when i go full screen the game display is very dark and is ruing my enjoyment of the game...i have used dosbox previously and i was able to change the size of the window so it was almost the same size as the full screen display but with no loss of brightness/color.
At the moment the dosbox window is about a quarter of my full moniro display and it hurts having to squint at such a small display...and idea how i can change width/height of the dosbox window?
Thanks
Reply 1 of 2, by eL_PuSHeR
Rank Moderator
Moderator
SEARCH the forum. Read the readme. This has been asked several times.
EDIT:
Do you have latest video drivers for your videocard?
Have you tried setting different graphic outputs inside DOSBox?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 2, by Lofty
You could try setting fullfixed=true, and fullresolution to your desktop resolution (eg. fullresolution=1280x1024) in dosbox.conf. Using a high resolution may cause slowdown though.
Obvious thing comes to mind though - can't you just turn the brightness up on your monitor when it's dark? Modern monitors keep brightness/colour/etc settings independently for each screen mode.
