new error
First post, by Strumtruppen
simply mi dosbox denies to work when i fix mi rendering output problem then i have a new one ... i have the diagnostic window and the command window and in the command window i can't write¡¡¡¡¡¡¡¡
Solo por que no se pueda explicar , no significa que sea "dios"...
Reply 2 of 7, by Strumtruppen
version: 0.63 win32
in the dosbox.conf y just change the output to surface (because it doesn't work) to opengl
system:win98 SE
Reply 5 of 7, by Strumtruppen
well ive just discovered than i can write but i can't see what i'm writing check tehe screenshot is... well check it
    112.17 KiB
    150 downloads
Reply 6 of 7, by DosFreak
Download a CVS version from my signature.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 7 of 7, by Strumtruppen
😅 thank you so much "Dos freak" you realy have solved my problem 😁 thankyou again and thanks to all the people who bottered in answer and suggest a solution to my problem 😁
