new error
First post, by Strumtruppen
simply mi dosbox denies to work when i fix mi rendering output problem then i have a new one ... i have the diagnostic window and the command window and in the command window i can't write¡¡¡¡¡¡¡¡
Solo por que no se pueda explicar , no significa que sea "dios"...
Reply 1 of 7, by pred
give more data, such as dosbox version, dosbox.conf, system specs, etc, any info
Reply 2 of 7, by Strumtruppen
version: 0.63 win32
in the dosbox.conf y just change the output to surface (because it doesn't work) to opengl
system:win98 SE
Reply 3 of 7, by eL_PuSHeR
Try also the other settings for output=
overlay
ddraw
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 7, by Strumtruppen
nope .... something more to try??
Reply 5 of 7, by Strumtruppen
well ive just discovered than i can write but i can't see what i'm writing check tehe screenshot is... well check it
Reply 7 of 7, by Strumtruppen
😅 thank you so much "Dos freak" you realy have solved my problem 😁 thankyou again and thanks to all the people who bottered in answer and suggest a solution to my problem 😁
