First post, by deception
Hi guys,
I would like to know is there a way i should configure in order to let my app access the internel modem i have in my laptop?
is it by using directserial? cause i know if i use the "modem" line in my config.. it just activate the dosbox's virtual modem capabilities which i dont want..
Thanks
Reply 1 of 6, by DosFreak
Just dial your modem like usual and then use DosBox virtual modem function. DosBox cannot access your modem directly, AFAIK.
Make your games work offline
Reply 5 of 6, by deception
h-a-l,
i've tried your patch..
during the start initial startup of my dosbox, the status window shows this..
Serial1: Opening com3
Serial9600: Desired serial mode not supported (5,0,0,1
and after i quit my app this line was shown
Serial1: Errors occured: Framing 0, Parity 0, Overrun 5, Break 0
any thoughts on this? thanks..
