newbie Modem Qns
First post, by deception
Hi guys,
I would like to know is there a way i should configure in order to let my app access the internel modem i have in my laptop?
is it by using directserial? cause i know if i use the "modem" line in my config.. it just activate the dosbox's virtual modem capabilities which i dont want..
Thanks
Reply 2 of 6, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
If your modem provides a com port you can use directserial.
1+1=10
Reply 3 of 6, by deception
i tried the directserial method.. and it works!
now there's another problem with my app (CoSession 6.03)
any1 using it too?
Reply 4 of 6, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
There is a build with serial port fix on my homepage. May help if it locks up / has serial port related problems.
1+1=10
Reply 5 of 6, by deception
h-a-l,
i've tried your patch..
during the start initial startup of my dosbox, the status window shows this..
Serial1: Opening com3
Serial9600: Desired serial mode not supported (5,0,0,1
and after i quit my app this line was shown
Serial1: Errors occured: Framing 0, Parity 0, Overrun 5, Break 0
any thoughts on this? thanks..
Reply 6 of 6, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
The first errors are no fatal ones in this case.
The other you can try to avoid by increasing the cycles (ctrl+F12 or set it in dosbox.conf).
1+1=10
