First post, by seraphimdreamer777
I just got the King's Quest Collection and I don't know how to get it working .I tried to play the games but all that happens is a window with a black screen opens for a second and then closes automaticly.
Reply 2 of 7, by avatar_58
Qbix wrote:
compilation or collection ?
Actually to further add to the confusion, the newer compilations actually say "King's Quest Collection" right on the box. So the question becomes: is this the old collection or the newly released one?
Reply 3 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
if it is the new one. Did you try contacting Sierra/VUgames about it ?
If it is the old one. Which DOSbox version are you using.
Water flows down the stream
Reply 7 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
you are probably suffering from this DOSBox: neither rendering works using ATi Rage graphics
The fix described there isn't needed if you install 0.65
You should really contact Sierra about this. Afterall it is their compilation.
