First post, by dhruba.bandopadhyay
I need something cleared up. There's a setting in DOSBox.conf file that says:
ipx=true #enable IPX emulation over IP/UDP
Does that mean it converts the IPX packets so it works over UDP. Does that mean we can play DOSBox over the internet, since UDP is a internet related protocol?
Please sign the Blood source code release petition
Reply 3 of 6, by MiniMax
Rank Moderator
Moderator
DosBox Guide to Multiplayer Games
_________________
Reply 4 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
which is a bit outdated
at least when it comes to the problem mentioned with games at the bottom.
Water flows down the stream
Reply 5 of 6, by leileilol
I did a IPXNET game of ROTT with a friend before, worked
PS. I've never gotten OMF2097 or Tyrian netplay to work on actual DOS systems at all either, so those are pretty bad examples.
long live PCem
FUCK "AI"
Reply 6 of 6, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
I currently don't know any games that do not work.
1+1=10
